Re: Solid Works Models.... [Re: mr_340] #1631558
06/12/14 05:22 PM
06/12/14 05:22 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
There is a lot more to that head drawing than that one view. A friend, Stewart, scanned that drawing and sent me a copy in sections. I think the original drawing is about 8'-10' long, probably 44" high. The auto industry doesn't seem to believe in multiple sheets. I worked a contract gig with Atco Products last year and we did some replacement parts for Ford and the drawing format was 44" x 72". All sorts of views all on one sheet.
Agreed. I don't think you're going to get a complete set of drawings for a block or head from anyone. I used to work on turbine blade designs for Pratt & Whitney and there are many drawings for a cast part. The easiest method would be to 3D scan a block and/or head and create the model from that. You still wouldn't have the internal passages for the cooling fluid but at least you could have a nice model of all exterior features. I was visiting a company a few years ago when I was looking at buying a 3D printer for the company I work for and they demonstrated how they could scan a part (Holly dominator main body in this case) and create a solid model from it. Pretty neat technology.
Re: Solid Works Models.... [Re: blowndart] #1631559
06/12/14 05:52 PM
06/12/14 05:52 PM
Taxes & Virus's R-US, NY
Dragula Online content OP
Dragula  Online Content OP
As stated Automotive drawings are very long I have a couple of complete brand X engines, and they are probably 20ft OAL and I just put the machine into auto fold, and it makes a book out of them or you can leave them as a roll. I actually have a few of them scanned as well, just no Mopar ones.
I started my BBM model and the oil pan and timing cover bolt holes are all pretty good, but I do not have the valley, the head deck, and oil & water passeges detailed. When the weather turns bad for winter again I will resume my little project.
So if someone has a model of their Mopar parts I would be willing to trade as I detail mine out further. Obviously its a lot of work. Place up the road will scan a block for about +$350 or so...I should have them do one of my Hemi heads this winter.
Re: Solid Works Models.... [Re: blowndart] #1631560
06/12/14 05:53 PM
06/12/14 05:53 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
Yes it is. I'm a machinist/CNC Programmer. I use SolidWorks and CAMWorks. I make a lot of my own stuff. I always wanted a 3D model of a BBM so I could mock up more of my ideas.
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: Solid Works Models.... [Re: Dragula] #1631561
06/12/14 06:21 PM
06/12/14 06:21 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I would be interested as well, I had a few things modeled, but lost the harddrive.
Having a block scanned would be great, maybe some folks would like to chip in and split the costs, if there was enough interest.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Solid Works Models.... [Re: OUTLAWD] #1631562
06/12/14 06:49 PM
06/12/14 06:49 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
That would be worth looking into
Greg
Re: Solid Works Models.... [Re: Dragula] #1631563
06/12/14 07:05 PM
06/12/14 07:05 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
I'd be in for $50 of the total costs.
Also, I have the head deck modeled with bolt holes , bore locations, oil passage location, water passage locations, and dial pin locations. Shoot me a pm with your email and I will get a step file to you.
Adriel Paradise
Substation Design Engineer III
Re: Solid Works Models.... [Re: Adrielp] #1631564
06/12/14 07:19 PM
06/12/14 07:19 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
I'll match your $50
Greg
Re: Solid Works Models.... [Re: 1320Dart] #1631565
06/13/14 02:33 AM
06/13/14 02:33 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
I will be scanning some small block stuff when I get time to do so. I intend on doing a head, block, and timing cover at some stage this year. I am also going to do a 904 trans case while I am at it. Might do some intake manifolds if I can get my hands on them.
Alan Jones
Re: Solid Works Models.... [Re: LA360] #1631566
06/13/14 04:39 PM
06/13/14 04:39 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
Emails sent guys.
Also, could you please let us know once you get the SB and transmission stuff scanned. That would be awesome to have.
Adriel Paradise
Re: Solid Works Models.... [Re: Adrielp] #1631567
06/13/14 04:56 PM
06/13/14 04:56 PM
So I am not the only one wanting to do this.....
Re: Solid Works Models.... [Re: Dragula] #1631568
06/13/14 05:31 PM
06/13/14 05:31 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
I can't open step files without someone helping me convert it to a parasolid x_t, which works best for our current 3D program.
I am in for sharing CAD drawings, both dwg and 3D.
Tom
Re: Solid Works Models.... [Re: RT540] #1631569
06/13/14 06:07 PM
06/13/14 06:07 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
I have the ability to convert stp to XT files. You may also want to look at downloading a file converter online. I'm pretty sure there are quite a few free softwares available.
Adriel Paradise
Re: Solid Works Models.... [Re: RT540] #1631570
06/13/14 06:29 PM
06/13/14 06:29 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I can export adriel's step files to a 3d dwg or any other autodesk program if needed.
Re: Solid Works Models.... [Re: DJVCuda] #1631571
06/13/14 08:57 PM
06/13/14 08:57 PM
LA360 Offline
LA360  Offline
Don't know when I will get to scanning everything, it will be sometime later in the year I would imagine.
Alan Jones
Re: Solid Works Models.... [Re: LA360] #1631572
06/14/14 05:49 AM
06/14/14 05:49 AM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Thanks for the offer to help me with exporting to X_T and 3D DWG, which both works well for Vectorworks.
I have a college at work who can export files from SW 2012 for me, only problem is, the solids turns into generic solids and increase in size, so we almost always makes new solids from the old ones.
Maybe everyone already got these, but I have had good use for them for both mid plates and motor plates. Three PDF with dimensions of the block.
http://mail.tervento.se/bilder/6735107-BlockGeometry.pdf
http://mail.tervento.se/bilder/6730956-B-RB_block_front_dimensions.pdf
http://mail.tervento.se/bilder/6730958-B-RB_bellhousing_dimensions.pdf
Re: Solid Works Models.... [Re: RT540] #1631573
06/15/14 05:47 PM
06/15/14 05:47 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I tried to attach a SW file, but it wouldn't take it. We will have to find another place to upload them. Here is a JPEG of the part.
Floyd Lippencott IV
