Re: Headliner Install Question [Re: Crazy68Dart] #1630608
06/11/14 12:00 AM
06/11/14 12:00 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Not sure how your is made. My cuda had card board panels that went on afterwards. The Challenger I worked on first did not have those so it was tougher. I stretched it at far as I could and then glued and stuck them in the teeth.
Re: Headliner Install Question [Re: fastmark] #1630609
06/11/14 12:42 AM
06/11/14 12:42 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Maybe a little adhesive to hold it in place and some small clamps. Then check it a day later and stretch it again?
Re: Headliner Install Question [Re: fastmark] #1630610
06/11/14 09:03 AM
06/11/14 09:03 AM
Canton, Ohio
Crazy68Dart Offline OP
Canton, Ohio
Interesting you mention this... the headliner kit came with covered hard boards. I know for certain that the Dart did not have these when I took the old headliner out. I am pretty sure it was factory original. I'm not sure how or if they would be attached. Would the original sail panel boards be removed (the ones under the headliner) and these used on top in some way?
383, Hemi 4-Speed, AlterKtion, D60
Re: Headliner Install Question [Re: Crazy68Dart] #1630611
06/11/14 10:14 AM
06/11/14 10:14 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Some cars have them under the headliner. I have never done a dart so I'm not sure about yours.
Re: Headliner Install Question [Re: fastmark] #1630612
06/11/14 10:43 AM
06/11/14 10:43 AM
Canada
Dons Dart Offline
Dons Dart  Offline
Canada
I have done 3 69 darts in the past your on the right track so far,when starting the gluing on the sides ,like said front to rear,start with a good pull on the liner glue booth sides,when to get to the lower end neer the quarter glass glue it.NOW you will see the tack that is the at the very bottom of the rear glass,you see it pull just enough to stretch it fasten it,than glue the lower head liner to the package tray pull down you should have a bout 2 inches to play with.I have never seen as big a liner that you got.
Re: Headliner Install Question [Re: fastmark] #1630613
06/11/14 10:45 AM
06/11/14 10:45 AM
Canada
Dons Dart Offline
Dons Dart  Offline
Canada
ps i have never seen my 69 darts with separate sail panels.
Re: Headliner Install Question [Re: Dons Dart] #1630614
06/11/14 11:52 AM
06/11/14 11:52 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
The sheer size and the included sail panels tell me you got the wrong headliner for a Dart. B'bodies have those sail panels and they just are held in with one or two clips. I hope you can make it work for your application.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Headliner Install Question [Re: MOPARMIKE69] #1630615
06/11/14 09:41 PM
06/11/14 09:41 PM
Canton, Ohio
Canton, Ohio
There are boards *under* the headliner. A backer board if nothing else.
It does seem big, but the bows and seams are fine. I had it stretched last night and it looks like it is going to work okay.
I unclamped it all last night. I am going to go around and cut a little more off the listing so I can get more "stretch" on the sides.
What about the headliner "clips" along the sides? I have seen references to them, and I think they are used on the sides between the bows. Just not sure they are used on Dart/A-bodies. I don't remember any on the Dart when I took the old one out.
Re: Headliner Install Question [Re: Crazy68Dart] #1630616
06/11/14 11:51 PM
06/11/14 11:51 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Yes they have clips. I found some at the local yard and snagged them for future use.
Re: Headliner Install Question [Re: Crazy68Dart] #1630617
06/12/14 12:41 PM
06/12/14 12:41 PM
pa.
dan9 Offline
dan9  Offline
pa.
I can't see where using the clips could hurt anything. I glued along the pinchweld and used the clips at the listings.
Re: Headliner Install Question [Re: dan9] #1630618
06/12/14 05:16 PM
06/12/14 05:16 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
sorry, haven't gotten home from work with any spare time to hop on but YIKES!! that thing is huge! i agree, i think you got a b-body one. can't see why you can't get it to work though
Re: Headliner Install Question [Re: mikemee1331] #1630619
06/12/14 06:31 PM
06/12/14 06:31 PM
Canton, Ohio
Canton, Ohio
Not sure what the deal is on the clips. I bagged everything when I took the car apart. No clips to be found.
As big as it is there is what seems to be the appropriate amount towards the front. The sides and back are excessive though. Should be able to make it work though.
Re: Headliner Install Question [Re: Crazy68Dart] #1630620
06/15/14 04:20 PM
06/15/14 04:20 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
any update on this project??
