Re: 9.5 vs 8 inch converter for street/ strip car [Re: B3422W5] #1629594
06/13/14 12:18 PM
06/13/14 12:18 PM
Renton Washington
Triple Threat Offline
Renton Washington
I think a low first gear would highly benefit the little 318 that could. This would also help cover up for the lack of rear end gear.
Only downside, if you build a big stroker in the futre, the 2.74 first might be too aggressive.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 9.5 vs 8 inch converter for street/ strip car [Re: Triple Threat] #1629595
06/18/14 01:37 AM
06/18/14 01:37 AM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Dustin..... Stop making good suggestions. Your costing me money... Lol
Anyhow, made a deal to buy a nicely done 904 today. I now have the car, a motor for it, and a convertor.
Next, need new ring and pinion and bearing kit to swap to 4.10.
Frame connectors
Driveshaft loop
Driveshaft... 727 to now 904
It may or may not need axles. The rears have 3 inch race/long studs sticking out, so maybe they are aftermarket.
I haven't raced in quite a while, and a 50 mile jaunt this afternoon has me chomping at the bit, but I hope to transform this car to where I can race it here soon, real soon.
I am honestly curious to see what a healthy little pumpgas 318 will run in full street trim out the tips with my tubby carcass behind the wheel.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
