Re: Smokin Hemi...
[Re: Xlr8us Rapidus]
#1628977
06/08/14 04:06 PM
06/08/14 04:06 PM
Posts: 1,411 Western NY
Xlr8us Rapidus
super gas
super gas
Western NY
Think I found the problem. #4 intake rocker is broken! Not sure why yet. These are a used set of Norris 1.7s. [image] [/image]
Re: Smokin Hemi...
[Re: Cab_Burge]
#1628979
06/09/14 08:35 AM
06/09/14 08:35 AM
Xlr8us Rapidus
super gas
super gas
Western NY
The broken intake rocker should make the motor miss, not smoke
If the intake valve is not opening the piston is still pulling a vacuum, it's pulling oil past the rings and seals.
Re: Smokin Hemi...
#1628980
06/09/14 11:57 AM
06/09/14 11:57 AM
Posts: 75,102 A Banana Republic near you.
JohnRR
Did a leak down after warming engine and removing plug tubes. Only checked #1, 2 and 4. About the same results from all. 40% leakage... that don't sound good. Sounds like air under the blower.
IF you found 40% leakage I think you found the problem ... and it's not a broken intake rocker ... if the air is not coming out the intake or the exhaust then that leaves the rings ...
Re: Smokin Hemi...
#1628981
06/09/14 12:12 PM
06/09/14 12:12 PM
Challenger 1
Cincinnati, Ohio
[image][/image]
Blowers create boost as you know, but also put a incredible strain on the rockers, push rods and lifters, a lot of strain. So you need a good valve train, I have no idea about your rockers?
The broken rocker is not the reason for 40% leakage, I'm betting the rings didn't seat during break in usually because of the wrong fuel mixture during break in.
Good luck with it, did you build it?
