Re: Best intake manifold to use with 1970 coronet with 440? [Re: diesel] #1628483
06/05/14 03:29 PM
06/05/14 03:29 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I checked the base and it sits steady on a table. It was also marked by the seller as a 440 baseplate. I was hoping that it was the wrong part thus fixing the problem. The lid was marked by the seller as a 383 lid though... are there any differences in lid heights? I never knew there was any height difference for a 383 and 440 air grabber, so it never occurred to me that the lid or base could be the problem. The engine in the car is a mild build and seems to like the performer that is currently on her, is there a noticeable performance difference between the m1 dual plane or CH4B and the performer thats currently on her? I would be seriously considering the M1 if it is the factory height as it should definitely fix the problem?? The hood will close with just the baseplate on but once you add the filter and lid,a definite no go. So I believe I need maybe an inch or lil more clearance because the filter doesn't sit very high. I again wish to thank everyone who is sharing their opinions and knowledge.
A member with a 69 road runner tried the CH4B on advice that I told him it would clear , it didn't. I ASSuMEd the CH4B was stock height because it was NHRA legal in Stock class racing and carried a Chrysler part number.
The ONLY intake in alum that is the same height as a stock iron intake ... that I know of , is the OLD M1 dual plane , I'm pretty sure the current M1 dual plane is a rebadged Performer RPM , no way that is fitting without surgery.
The bases are different between 383 and 440 , 383 is taller , lid and filter is the same .
When you say you checked the base and it sits steady on the table , what parts hits the table ? With the 383 baseplate the only part that touches the table will be the ring that sits on the carb.
Re: Best intake manifold to use with 1970 coronet with 440? [Re: JohnRR] #1628484
06/05/14 03:44 PM
06/05/14 03:44 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Is the Edelbrock carb the OP using the same height as the stock AVS carb?
Re: Best intake manifold to use with 1970 coronet with 440? [Re: autoxcuda] #1628485
06/05/14 05:51 PM
06/05/14 05:51 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Yes, it should be. Mine is
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Best intake manifold to use with 1970 coronet with 440? [Re: JohnRR] #1628486
06/05/14 06:01 PM
06/05/14 06:01 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
hell has just frozen over........ (i just couldn't resist! )
Re: Best intake manifold to use with 1970 coronet with 440? [Re: JohnRR] #1628487
06/05/14 07:18 PM
06/05/14 07:18 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Pretty important point that I regularly fail to mention. Less experience folk might not realize this potentially leading to some frustration. Good catch.
Re: Best intake manifold to use with 1970 coronet with 440? [Re: BSB67] #1628488
06/06/14 01:23 AM
06/06/14 01:23 AM
Fredonia, NY
diesel Offline OP
diesel  Offline OP
Fredonia, NY
It pretty much sat flush on the table. I am attempting to post a pic of it. I am assuming this means it is the correct base plate. A kind moparts board member has offered to sell me a factory cast iron intake that I think I am going to try. If that does fix all my problems, I will in time be looking for a M1 dual plane intake for the little bit of performance increase. I like how my performer works, I just want to be able to use this air grabber air cleaner. It seems that the M1 will be the closest in performance. What years of the M1 are what I would need? Is there a specific part number that refers to the correct one?
Re: Best intake manifold to use with 1970 coronet with 440? [Re: Slant6pak] #1628489
06/06/14 01:46 AM
06/06/14 01:46 AM
Mesa, Arizona
dart4forte Online boogie
dart4forte  Online Boogie
Mesa, Arizona
The old Edelbrock CH4B may fit as well.
Excellent manifold
Re: Best intake manifold to use with 1970 coronet with 440? [Re: dart4forte] #1628490
02/20/15 05:19 PM
02/20/15 05:19 PM
MD
p d'ro Offline
p d'ro  Offline
MD
Does anyone have a part number for an old M1 dual plane for a 440?
Re: Best intake manifold to use with 1970 coronet with 440? [Re: RapidRobert] #1628491
02/20/15 05:25 PM
02/20/15 05:25 PM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
Holley Sd is probally the best of both worlds.Plus its pretty low.Ran it on 3 BBs and loved it.Rocky
Chrysler Firepower
Re: Best intake manifold to use with 1970 coronet with 440? [Re: diesel] #1628492
02/20/15 06:21 PM
02/20/15 06:21 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Welcome,
Good advice here. I'd love to see some pics of your car...also check out the 70 coronet FB page here: https://www.facebook.com/groups/3150910068/
Not to pick nits, and I'm a bit surprised that nobody else mentioned it but a '70 Coronet never came with an "Air Grabber"....only a "Ramcharger " fresh air hood.
....there is one other manifold that works and is available in aluminum ...
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Best intake manifold to use with 1970 coronet with 440? [Re: DPelletier] #1628493
02/20/15 09:28 PM
02/20/15 09:28 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
One option on the air cleaner, although I would never do it to a good factory ramcharger plate is to buy a drop base air cleaner and graft it where the filter rides to a ramcharger base. Should work to allow you to run whatever intake you would like and give you clearance.
Careful, your character's showing!
Re: Best intake manifold to use with 1970 coronet with 440? [Re: DPelletier] #1628494
02/21/15 05:26 PM
02/21/15 05:26 PM
JohnRR Offline
JohnRR  Offline
Re: Best intake manifold to use with 1970 coronet with 440? [Re: JohnRR] #1628495
02/21/15 09:35 PM
02/21/15 09:35 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
when i bought my 70 coronet it had a 440 with a weiand stealth intake on it, part number weiand 8001, looks like stock height but is lighter. i dont run the air grabber on it though so not sure but maybe someone can chime in, good luck.
