Page 2 of 4 1 2 3 4
Re: Fuel Pressure Regulator w/ Return to Help Vapor Lock [Re: cjskotni] #1628240
06/04/14 06:35 PM
06/04/14 06:35 PM
Georgia
Steve Bryant Offline
Georgia
The four lines there ran right back into the tank so it vented quite well. Of course I am not 100% sure why my setup had this since it was just a 318 on an E-Body.
Re: Fuel Pressure Regulator w/ Return to Help Vapor Lock [Re: Steve Bryant] #1628241
06/04/14 06:57 PM
06/04/14 06:57 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Notice the brass or copper tips on the vent lines. I guess to prevent sparks?
See how the separator is positioned, all vent lines enter the bottom where it can drain back and the actual vent nipple where the vent line attaches is up top.
Actually I believe the 1/4" return was clamped to the other 2 lines from the factory and not in the bolted on clamps, they have these s hooks that hold the line to the other lines. This is the only place I put all three in on e clamp on this car, they don't really fit.
Re: Fuel Pressure Regulator w/ Return to Help Vapor Lock [Re: Challenger 1] #1628242
06/04/14 07:13 PM
06/04/14 07:13 PM
The four vent lines in the tank to each corner are to ensure that all the air is pushed out when filling the tanks on those cars that had that system, my 1971 Duster was one of them. It took the last 3 or 4 gallons very slowly, just like my 2006 Ram 3500 CTD does on the last 2 gallons
Re: Fuel Pressure Regulator w/ Return to Help Vapor Lock [Re: Cab_Burge] #1628243
06/04/14 07:48 PM
06/04/14 07:48 PM
Cincinnati, Ohio
Cincinnati, Ohio
In other words, it allows the tank to totally vent.
Re: Fuel Pressure Regulator w/ Return to Help Vapor Lock [Re: Cab_Burge] #1628244
06/04/14 07:54 PM
06/04/14 07:54 PM
dogdays Offline
dogdays  Offline
Some of the confusion is due to incorrect terminology.
The VAPOR SEPARATOR is to keep vapor out of the carburetor. That's what the filter with the extra fitting is for. I believe that if one looks up into the smaller tube coming off the filter, one sees a smaller hole (orifice) where the tube connects to the filter body. The return line conducts the vapor and whatever liquid fuel flowing through the orifice, back into the fuel tank. Otherwise, where would it go?
Now on to the back of the car. In 1971, maybe earlier, Federal regulations required new cars to control emissions of fuel evaporating from the gas tank. This is called EVAPORATIVE EMISSIONS CONTROL. It controls evaporative emissions by collecting the vapor that exists in the top of the tank and catching it in either a larger container where the evaporated fuel can condense and run back into the tank, or else into a charcoal canister that is plumbed to the engine intake, so that the evaporated fuel is eventually burned by the engine. This had NOTHING to do with preventing vapor lock, and was not primarily intended to allow the complete filling of the tank. It was a response to a Federal mandate.
My 1972 Nova had the charcoal canister. My 1971 D100 had a simple vent line going to a larger segment of tube, which I think had an overflow that went through the floor.
Starting whenever the Federal mandate went into effect, gas caps were NO LONGER VENTED.
There is nothing about the evaporative emissions control system that harms performance. (Well, maybe it adds a pound or two of extra weight.) Removing it only demonstrates one's ignorance.
R.
Re: Fuel Pressure Regulator w/ Return to Help Vapor Lock [Re: dogdays] #1628245
06/04/14 10:05 PM
06/04/14 10:05 PM
IN
ahy Offline
ahy  Offline
IN
R.
The 3 prong filter has an orifice so it does not drop fuel pressure too much. Its supposed to be around .050". Running the return back to the 1/4 nipple on the sender should be fine. In normal operation it will simply dump some fuel back in the tank and the circulation will keep things cooler to help prevent vapor lock. If the line gets hot and vapor does form, the separator will direct it back to the tank also. By the time it makes it back, it may cool and turn back to liquid but either way you are at least helping prevent vapor in the engine compartment.
Re: Fuel Pressure Regulator w/ Return to Help Vapor Lock [Re: ahy] #1628246
06/04/14 10:16 PM
06/04/14 10:16 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
If I got something like this:
Does it have 3/8" nipples for the in/out so it will work well with my fuel line? Also, how does this thing bolt to the engine so it doesn't bounce around?
Or do I need this style since my car is a 73?
Re: Fuel Pressure Regulator w/ Return to Help Vapor Lock [Re: cjskotni] #1628247
06/04/14 10:29 PM
06/04/14 10:29 PM
Cincinnati, Ohio
Cincinnati, Ohio
That's the hot ticket, be sure there is a restriction for the return. No you can't use 3/8".
5/16" is the correct outlet size with a 3/8 inlet on the fuel pump. That how the fuel pump works best.
Everyone is hung up on 3/8, you don't need 3/8 from the pump to the carb. Even 3-2s or a hemi screaming at full song, as evidence of this filter/separator is only supplied by 5/16. It's a short run and 5/16" is more than enough.
Re: Fuel Pressure Regulator w/ Return to Help Vapor Lock [Re: cjskotni] #1628248
06/05/14 06:50 AM
06/05/14 06:50 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I used the Carter performance pump, and Hemi vapor separator, and did not have any fuel problems.
The reproduction vapor separator is expensive, I think $50, but it is setup for 3/8" lines. The fuel filters with vapor port I think are 5/16" fuel line, but only cost a few bucks. Really, you could just add a "T" to the fuel line before the carb, and install a restriction in the line that returns to the tank. You just want to maintain a minimum steady flow of fuel through the fuel pump and lines.
Re: Fuel Pressure Regulator w/ Return to Help Vapor Lock [Re: 451Mopar] #1628249
06/05/14 08:32 AM
06/05/14 08:32 AM
Indiana
Y
YO7_A66 Online content
YO7_A66  Online Content
Y
Indiana
"" Really, you could just add a "T" to the fuel line before the carb, and install a restriction in the line that returns to the tank. You just want to maintain a minimum steady flow of fuel through the fuel pump and lines""
The brass fitting that I shown in my previous reply is in this "T". 3/8" in and 3/8" out and I can adjust the flow back to the tank with a simple jet change. It is not stock but it flows well.
Re: Fuel Pressure Regulator w/ Return to Help Vapor Lock [Re: YO7_A66] #1628250
06/07/14 03:57 PM
06/07/14 03:57 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Well I pulled the fuel pump and checked the push rod and compared it to the new rod I just got from Mancini. The rod is the exact same length as the new one with no wear I can discern. I am guessing a worn rod isn't my issue. :-(
If this isn't vapor lock, I am open to suggestions on what else to check...
As far as the hemi/440-6 setup, how did the factory hook all that up? Was there a hard line from the pump outlet to the vapor separator inlet? Did you just use a barb on the outlet and run rubber line to the separator? Where does that little tab on the vapor separator mount on the engine?
Thanks!
Re: Fuel Pressure Regulator w/ Return to Help Vapor Lock [Re: cjskotni] #1628251
06/07/14 04:05 PM
06/07/14 04:05 PM
Cincinnati, Ohio
Cincinnati, Ohio
Bummer it wasn't the push rod.
It bolts to the fuel pump, like I said above. All barbed fittings and rubber hoses.
One is suction and the smaller the return. The upper line is my gas tank vent, it'll connect to the breather on the valve cover. Get it??
Re: Fuel Pressure Regulator w/ Return to Help Vapor Lock [Re: Challenger 1] #1628252
06/07/14 08:44 PM
06/07/14 08:44 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Thanks for the pictures! I ordered the return line, vapor separator, and a hemi fuel pump (3/8" inlet). I am going to ditch the Holley just in case that is the issue.
Is this going to be a pretty sure way to fix this vapor lock issue? Is there anything else I need to do to help this or will the return line pretty much get rid of it?
Thanks!
Re: Fuel Pressure Regulator w/ Return to Help Vapor Lock [Re: cjskotni] #1628253
06/11/14 08:25 AM
06/11/14 08:25 AM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
I should have some of the parts creeping in here soon...
Do I need/should I use any type of fuel filter between the separator and the carburetor? Will this separator be enough to strain the fuel and keep the carb from getting trash in it?
I also thought of why the 73+ style VS has the funky bracket as those years originally had the passenger side exit on the WP housing. I am guessing this would interfere with the placement of the VS right on the pump there. Luckily I switched to the driver's side WP housing on mine years ago to make it easier to find an aluminum radiator that would work.
If this doesn't fix this stalling issue, I think I am going to this car and collect insurance money!
Re: Fuel Pressure Regulator w/ Return to Help Vapor Lock [Re: cjskotni] #1628254
06/11/14 11:45 AM
06/11/14 11:45 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Did you ever check to see if fuel is drippling in the secondary venturis while the car is ideling after a few minutes?
Mike
Re: Fuel Pressure Regulator w/ Return to Help Vapor Lock [Re: cjskotni] #1628255
06/11/14 03:02 PM
06/11/14 03:02 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
I'm a little late to the party however, if your hood clearance permits, consider adding a carb spacer/insulator.
Another simple solution is "T" off of the rear, secondary carb feed line. This added outlet coming off the carb feed line can then either be ran back to the 1/4" port on the sending unit or use a fuel filter with an added port such as Fram filter G3499 and run the return to the filter. If you run it back to the tank, this provides a loop or circulating fuel system.
Re: Fuel Pressure Regulator w/ Return to Help Vapor Lock [Re: cruzin] #1628256
06/11/14 05:14 PM
06/11/14 05:14 PM
dogdays Offline
dogdays  Offline
Putting an electric pump back by the gas tank, shielded from exhaust heat, is the best way to eliminate vapor lock. Remove the mechanical pump. Run a return line to move a little fuel all the time.
R.
Re: Fuel Pressure Regulator w/ Return to Help Vapor Lock [Re: DAYCLONA] #1628257
06/11/14 09:55 PM
06/11/14 09:55 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
I am not sure if I am going to be able to get a hard line to fit from the VS to the carb inlet as my application is non-oem with a high rise intake and the dual fuel line for my Holley. Would it be safe to run just rubber hose from the VS outlet to the carburetor fuel fitting...maybe 18" or so?
I have not as I pulled the pump to check the push rod and the car is laid up now until I get this fuel system put back together. Why am I checking for this?
I have a 1/4" composite carb gasket so that should help here.
Never gonna happen on this car. I know electric fuel pumps can combat vapor lock but they can add a whole other host of problems. I am going to stick with mechanical on this car. I am adding the return line though.
Re: Fuel Pressure Regulator w/ Return to Help Vapor Lock [Re: cjskotni] #1628258
06/11/14 10:06 PM
06/11/14 10:06 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
having a dual inlet carb makes it easy to fab an inexpensive return line. dont try to reinvent the wheel.
I am truckless..
Re: Fuel Pressure Regulator w/ Return to Help Vapor Lock [Re: cjskotni] #1628259
06/12/14 12:01 AM
06/12/14 12:01 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Your chasing a lot of "ghosts" looking for the one that's causing your fuel woes, I'm trying to steer you towards the basics, so that you can eliminate them from your list....based on the descriptions of your fuel woes, a leaking rear (secondary) float/needle assy can cause a car to run ragged at low speed cruise conditions, or stall at idle/low speed conditions, and result in troublesome restarts after stalling due to the excess fuel conditions, it can be perceived as a no fuel situation, when in actuality the engine is flooded, simple test, with the engine idling, give it a few revs, then let it idle, check the rear/secondary venturis with your finger if they are wet with gas, or you can see visible signs of gas dripping from them, or the air bleeds, you may have a "sunk" float, or bad /dirty needle assy
Mike
Page 2 of 4 1 2 3 4
