Re: 11.75 rotors and viper calipers
[Re: brads70]
#1628049
06/06/14 02:06 PM
06/06/14 02:06 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I run the HP+ pads at the track lol. And stock Napa rear shoes on my 11" drums. It's the bomb imo. I'm not gonna get to froggy until I get a set of rear discs.
Mopar to the bone!!!
[Re: AlexP]
#2136710
08/19/16 04:39 PM
08/19/16 04:39 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Picking up on a older thread... as most of you may know, I use the car for serious pylon autocross in the past, but in recent years I'm running road course events.. HSAX/HPDE... avg speeds ~80mph (occasionally up to 110-115mph top-end and maybe a little faster in the near future).... its street/hwy driven (maybe another trailer in the future).
I'm at a crossroads decision to upgrade from my current 10.75" front power disc brakes to the 11.75" dia rotors (Cordoba, etc). I have multiple rim choices that I want to keep and use, pending my different events, etc.
I intend to use my 15x8 vintage mini-lite rims for street/hwy cruising, although I may eventually run the 15x7 factory steel rally rims (maybe going to 15x8 chrome rally rims for the front and 15x10 chrome rally rims for the rear... then using my aluminum 15x8 vintage mini-lite rims with Hoosier autocross tires size 275-50-15 f/r.
Also have a couple sets of 16" dia rims for various purposes; not yet planning, if ever, to get 17 or 18 diam rims... those are e few years away, if ever.
I recently acquired a pair of 73 up A-body disc spindles (large bearing design). I was going to get the Wilwood light weight calipers (with dust seals) as has been promoted/written in various articles, BUT.. it seems that the special caliper bracket from AREngineering (or Dr. Diff?) is no longer available to adapt the Wilwood calipers.
SO, if I install the large-bearing spindles (73-up disc A-body) which I have aside, then I'll have to install the heavy cast-iron calipers (again, Cordoba, etc) with the 11.75 rotors. Perhaps that'll be OK and show some noticeable braking improvement... my factory 10.75 discs and iron calipers have, in my opinion, worked fine for all the past ~40 years of duty/racing, even at the recent HSAX/HPDE track events. I've been using older semi-metallic asbestos pads from Wagner (yes... they are old, but I have a few sets to use up... and they work fine for me. (I'm aware that Dr Diff sells this as a kit, I'd simply negate the spindles since I already have them.)
In the rear, I have stock drums (small, 10" non-finned drums)... light weight compared to the larger 11" finned drums). I DO intend to get the Dr. Diff 10.7" rear disc setup pretty soon.
BUT,... I've just run across a potential purchase of the Viper gen-1 calipers, drum spindles, lines, etc (possibly coming off a Mopar e-b body... not sure about that... I believe this is an older Dr. Diff setup... I'll inquire further.. the older setup requires pad/caliper spacers and uses the 1" thin Cordoba rotor). It seems the gen-1 Viper calipers are difficult to purchase by themselves (I've seen they want core exchanges), and very expensive!
SO, what do you think is the better choice for me, keeping in mind the rims I intend to use, in particular the potential future usage of the factory-style 15" rally rims? I know the Viper calipers MAY not fit within the factory rally rims, but they will fit factory steel 15x7 cop-rims (including the 15x8 Super Coupe rims, I believe).
My interest is best performance and allowable 15" rims that i described.
I'm also aware that Dr Diff offers adapters for the Viper gen-1 calipers, along with thicker 11.75 C-body rotors at 1.25" thickness (instead of the thinner common Cordoba rotors at 1"). Granted, the thicker rotors would probably be better for long-life on the road race tracks for HSAX/HPDE... again, something to consider.
My car has been all apart (engine out/suspension/engine bay all being re-done) and is slowly getting back-together... aiming at the 2017 race season for my return.
T/Anks ahead for any advice and feedback.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: AlexP]
#2137089
08/20/16 03:40 AM
08/20/16 03:40 AM
72Swinger
Nebraska
You may also be able to use Dr. Diff's GM metric caliper adapters and then use Wilwoods D154 aluminum calipers that fit those. That might be the lightest setup with the 11.75" rotors.
[Re: 72Swinger]
#2138117
08/21/16 08:11 PM
08/21/16 08:11 PM
Mopar Mitch
T/Anks... I'll have to look into that option... wasn't aware of it.
Mopar Mitch
[Re: Mopar Mitch]
#2138220
08/21/16 11:11 PM
08/21/16 11:11 PM
Posts: 373 sandwich IL
sublimehemi
sandwich IL
hi mitch....i have this viper cass c body rotor kit and the 10.7 cass rear set up..i am running 15/16 cass master and stock 4 wheel drum prop vavle...cass said with this set up it is almost perfect bias as i am not using any adjustable prop valves..seems to be right on the money...pedel is not to hard and i have fallen in love with this set up...note c body rotors that are 1.25 are heavy...very heavy but will aid as a nice heat sink if your gonna use them...
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
[Re: sublimehemi]
#2138487
08/22/16 12:20 PM
08/22/16 12:20 PM
Mopar Mitch
Sublime -- T/Anks for the feedback... We're not too far apart... I'd like to meet with you sometime.
Mopar Mitch
[Re: AndyF]
#2148914
09/06/16 04:22 PM
09/06/16 04:22 PM
Mopar Mitch
Andy -- T/Anks for the tip on the light-weight discs... would like more info when available.
I met with Sublime hemi over this holiday wknd... he has an AWESOME 70 Charger!!!!
I tried different rims over the 11.75" rotors with the Viper calipers.... the factory 15x7 steel rally rims will NOT clear over the calipers... the inside radius of the design of the rim hits the caliper.
I tried my PERFORMANCE-brand vintage 15x8 mini-light rim... it just bareley clears, BUT having inside tape-weights just barely touches and scrapes the top of the front leading edge of the caliper (so, removing that ~1/8"-3/16" thickness weight would allow it to clear... that would mean using clip-on wheel weights (which I don't like as they'd probably damage the aluminum rim... not sure about that).... or else, filing-down the caliper at that interfering edge.
I also tried my Wheel Vintique 16x8 minilight rim... it clears better around the diameter, but... the flat spokes come close to the side of the caliper... clears by about 3/16".
And, I tried my 16x10 Centerline -X-series race rims (aluminum, zero offset (5" backspace)... clears a-ok.
SO... I may end up talking a pass on the Viper setup and just go with the cast iron Cordoba calipers.
BUT... I wish the Wilwood caliper adapters were still available from AREngineering and/or DrDiff... this way I could use light-weight calipers (hoping they would be a good choice or at least equal to the cast iron calipers).
Also, using the drum spindles limits the choices... using the disc spindles (say, '73 and up large size) allows more future brake choices from different suppliers, etc. (I have the drum spindles aside and the small disc spindle on the car, with the large disc spindle aside to be installed... all pending my final decision.)
T/Anks again to Mike... aka SublimeHemi!
Mopar Mitch
[Re: jbc426]
#2150190
09/08/16 07:17 AM
09/08/16 07:17 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Doctor Diff sells a light weight, aluminum adapter to bolt them right on. Hmmm.... I wonder if this change actually results in any improvement in regular street use. Not bashing anything here. I just recall reading an article in Mopar Action years back where they had a stock type single piston iron caliper on one side and a Viper caliper on the other. The car stopped straight during street stops. If the only advantage is for track use, 150 mph stops, I don't know when I'd be able to use the extra force.
[Re: Kern Dog]
#2150456
09/08/16 05:09 PM
09/08/16 05:09 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You're not getting any appreciable change in force.
The bigger brakes give you more thermal capacity. Get more heat out and your brakes are more effective under harsher conditions.
