Re: Had a blast at the racetrack [Re: Quicktree] #1626298
05/29/14 07:57 PM
05/29/14 07:57 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Even with a bolt in sprag with the stock number of roller
will break... the ultimate super sprag is said to not
blow.. mainly due to the number of rollers in it
I wouldn't trust that for a minute, even the super sprag can't stop that.
Tony that is the result of a blown sprag and I can tell you that the super sprag has 4 more rollers in the same space and would be hard pressed to roll over and fail.
it is really a ford C-6 sprag and I have seen very few of them fail over the years and the mud truck guys beat the hell out of them.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Had a blast at the racetrack [Re: dusturbd340W5] #1626299
05/29/14 08:45 PM
05/29/14 08:45 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I have heard that, but I wouldn't trust it. at a minimum a shield of some sort.
Re: Had a blast at the racetrack [Re: Quicktree] #1626300
05/30/14 06:45 AM
05/30/14 06:45 AM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
Dan Glad your atleast can walk I was in other lane ready for my burnout .Besides your foot a chunk just could have taken your head off or punture your heart .
i have the ulimate sprag and a shield .BUT a steel drum will go in this winter .
Many will say that they raced for years no problem .
You race more in one year guessing 300 plus pass's between 4 cars . .
Good luck hope you will recover fast and still want to race .
DR
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: Had a blast at the racetrack [Re: 10 o to go] #1626301
05/30/14 12:16 PM
05/30/14 12:16 PM
St. Louis Mo. USA
P
Pleaz Offline
Pleaz  Offline
P
St. Louis Mo. USA
Wow..that's scary.Its amazing how violent these tranny explosion are. Heal up quick Dan, its good to hear its just a broken foot....you'll be back in the saddle in no time.
Re: Had a blast at the racetrack [Re: Pleaz] #1626302
05/30/14 09:24 PM
05/30/14 09:24 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
probably not in that particular saddle....
Went through that same ordeal with a friends Challenger that was probably on a high 10 pass. Engine had been set back 6 inches and it had a tin floor in it. This was long before internet, and us not being local to a track were oblivious to the possibility of a trans explosion even occuring. After the autopsy we're quite sure the 8.75 gear let go first shocking the overunning clutch. When the drum broke it wrapped the tin floor around his right foot/ankle. Dents in the roof, wiped out all his Autometer gauges, and a chuck was stuck in the drivers door panel. He never went to the doc, but had a limp for a long time. After that all our torqueflights have had blankets. Personally I'd rather have the blanket than the TSC sheild as the blanket will absorb energy, but with the "rules" we'll be running a sheild.....might have the blanket over that if I can stuff it in there.
Re: Had a blast at the racetrack [Re: qwkmopardan] #1626303
05/31/14 01:04 AM
05/31/14 01:04 AM
ky
68roadrunner Offline
ky
sorry to hear dan, hope you get well soon, suppose you should have stayed at i57 and won some more money lol
