Re: Lets play guess the 6.2L supercharged Hellcats HP
[Re: WO23Coronet]
#1626192
05/29/14 03:45 PM
05/29/14 03:45 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If they're putting 11.6 PSI through it I'm going to guess 670ish, based on the Chevy #'s Malicious posted. I'm guessing it'll be as fast in the 1/4 as the GT500, yes the Challenger is heavier but that may help with traction. What kind of PSI does the GT500 have?
And weight tends to break parts.. sooner or latter they will have to lighten up all of those cars... I know when I was working there that was a big thing
[Re: SRT6776]
#1626194
05/29/14 09:03 PM
05/29/14 09:03 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
inside sources said it made 666hp..hense the name. Hellcat..but they will call it 665hp...to avoid controversy
According to aero charts it takes 700 HP to go 200 in a Challenger. (182 in the 470 HP NA 6.4L as a baseline)
i dont think they where limited to 11psi of boost on those passes..are they?
I edited my post (got the numbers wrong), 700 HP to go 214 MPH, 600 to go 198 and 470 to go 182.
What would be the point of running it at higher boost?
Do we have any more information on the block? Are they using the 6.4 block? Never will be able to justify buying one but don't care. If that block will take a blower if will handle anything I could throw at it. If its the same block its available in the 2500 and 3500 truck.Matt
[Re: dvw]
#1626197
05/29/14 11:13 PM
05/29/14 11:13 PM
Posts: 8,165 Left Coast
BobR
Left Coast
There expensive for 2 reasons. Profit and the government. They can only sell a few due to mileage requirements. So as a business they make a premium. I've driven them, but can't afford one either. If they wanted to, the power level could go way past 700 and live. But we know that the Viper and Ferrari are at the top of the food chain. Think of it this way. Use Chryslers technology and parts to build yourself a 1000 hp in something that weighs 3500lbs, you'd have one heck of a street car. Doug
I got my new 2013 ZR1 for $108,000.00 which was 19 grand under sticker. It does a lot of things well but traction on the stock cup tires is non-existent. If the Hellcat does have 666 hp I'd seriously look at one assuming it isn't just a great motor in an average car. I have a 2013 SRT8 Jeep and while the basic car is good the lousy detail and cheap part factor makes it only average.
[Re: MRMOPAR622]
#1626201
05/30/14 05:52 AM
05/30/14 05:52 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
From what I've read about it, this thing is gonna be built for abuse. It has its own transmissions, diff with only one ratio available, block, forged pistons,rods,crank, huge oil coolers, factory cold air through the d-side inside headlight, electric cutouts and its own 15.5" front brakes. Also it has been durability tested to withstand all out 20 minute track day sessions in desert heat without any power reduction. Most guys on here will say if it doesn't run 10's off the dealer lot its junk, this thing isn't built to dominate the strip, its being built as the ultimate musclecar.
Mopar to the bone!!!
[Re: Uberpube]
#1626202
05/30/14 07:47 AM
05/30/14 07:47 AM
Posts: 189 Virginia
64HemiSavoy
Virginia
It'll make 645 hp.. But in typical new mopar fashion, the car will weigh so much, it'll be stuck in the 12's.
Come out of your Mopar hating dream world.... Challenger stockers in the 9's od 10 inch slicks and if I remember right Barton ran some 8's in AA/SA trimwithout supercharger.
[Re: 64HemiSavoy]
#1626203
05/30/14 09:28 AM
05/30/14 09:28 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
a gutted out race car w/ a pro built engine, powerglide and solid rear is not the same as production car. I've seen plenty of R/T challey and SRT-8's at the track, some w/ mods haven't seen one break into the 10's yet. Most are in the high 12 range, some pop high 11's. That Hellcat thing I'd hope would be into the 10's, as mentioned before The S/C'd Mustangs have been there for a few years now.
[Re: Mr.Yuck]
#1626204
05/30/14 09:42 AM
05/30/14 09:42 AM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
IF they do a drag pak offering with the hellcat engine that should keep things interesting.
68 Barracuda Formula S 340
[Re: Bad340fish]
#1626205
05/30/14 10:34 AM
05/30/14 10:34 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Is the Hellcat just a engine or is it a car at this stage?Also over 600hp from the factory is more HP than a lot of Big Block & Small Block engines that have been built and are more Race than Street engines in street cars.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#1626206
05/30/14 10:39 AM
05/30/14 10:39 AM
fullmetaljacket
Car as a package. Aside from the engine and trans themselves, special brakes, calipers, wheels, rear end, shocks, hood, air intakes/exhausts, front grille, interior, emblems, etc.
[Re: MRMOPAR622]
#1626207
05/30/14 11:48 AM
05/30/14 11:48 AM
BobR
Left Coast
Nitto NTO5 Drag Radial is a good street/strip tire for the Vette's.My Super-Charged Calloway Vette makes over a 1,000 Rear Wheel Horse-Power on the chassis dyno.
I have those on my SC Cobra replica. 700 F/W HP. Never hammered it so I don't know how well they work.
[Re: WO23Coronet]
#1626208
05/30/14 11:13 PM
05/30/14 11:13 PM
Posts: 9,719 Home
SRT6776
I hate internal combustion engines!
Home
14
[Re: MRMOPAR622]
#1626209
05/30/14 11:17 PM
05/30/14 11:17 PM
Posts: 9,719 Home
SRT6776
Home
Its an engine that will be available in the Challenger and Charger.
Challenger Hellcat
