Re: Turbo Avenger
[Re: Hemi Allstate]
#1625170
06/09/14 11:44 PM
06/09/14 11:44 PM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
I hope to get to check out the Avenger in person and meet you next outing.
Mark
Yep, will get over and chat next time I plan on Friday at the Valley again this week. I just want it faster then my Valiant for now lol. It's a long way from hi 5's right now, but it's picked up a second or more since the 1st outing lol. Here is the other pass from earlier in the day. http://youtu.be/OXVaY3BoiSo
Re: Turbo Avenger
[Re: FastmOp]
#1625171
06/10/14 12:14 AM
06/10/14 12:14 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Don't you heat the tires?
Re: Turbo Avenger
[Re: pittsburghracer]
#1625172
06/10/14 12:18 AM
06/10/14 12:18 AM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
Looking good! It will be fun once ya get the bugs worked out!!
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Turbo Avenger
[Re: HOTMOPR]
#1625173
06/15/14 04:58 PM
06/15/14 04:58 PM
FastmOp
Hot Rod Ridge
Took the turbo hot rod out again last night. Made four runs and figured out a few things. Finally got it to shift, the logger worked like it should and I had good data after each run to tweak the fuel map. The last two runs I ran it out the back door and got some data to tweek the tune there. I picked up two seconds on my 1/8 mile times last night and its still pig rich in several areas. It had its best sixty foot, MPH, and ET. It has a hard pull when it's happy. And still has a bunch left. Slip looked like 1.49 sixty 6.21 at the 1/8 Only 105 MPH.
Re: Turbo Avenger
[Re: FastmOp]
#1625177
06/23/14 01:06 PM
06/23/14 01:06 PM
FastmOp
Hot Rod Ridge
Took the Avenger out again Sat. It's trying to wake up. Went in the 5's but still not faster then the Valiant lol. I am having shifter issues with the ACD air shifter. And I think I have some RFI issues but that's just new car blues. it has 12 passes on it now and I'm getting a feel for it. I'm really happy with the way it's coming around. It launches straight, stops well and drives nice. It's only making 3psi on the break so it leaves fairly soft. Then pins you in the seat about 60 feet out. http://youtu.be/WvPlxoFZ_Ec
