Re: Wow. Just wow. [Re: OzHemi] #1624882
05/25/14 11:57 PM
05/25/14 11:57 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Look on the bright side, at least it didn't break your vise.
This is probably the hardest I've worked that thing.
For a cheap Harbor Freight vise it's done fairly well.
Too bad it won't fit in a flat rate box...
If only I had a table for a vice...
Re: Wow. Just wow. [Re: feets] #1624883
05/26/14 12:09 AM
05/26/14 12:09 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
That old timer won't swing like the one I use.
Good point, be a shame to break it, while it is enjoying the golden years of retirement.
Re: Wow. Just wow. [Re: feets] #1624884
05/26/14 01:39 AM
05/26/14 01:39 AM
South
Squirrel_Cat Offline
South
My reward for all that work is complete disassembly for a thinner pinion shim.
I thought you had set it up! Crush sleeve is always last. Use your old inner and outer pinion bearings and hog them out with a burr so they are a slip fit. You now have setup bearings. Get the pattern right [without the crush sleeve]. Remove the setup bearings, press on the new inner, install the crush sleeve and new bearing...crank away.
1973 340 'Cuda 2013 Mustang GT
Re: Wow. Just wow. [Re: Squirrel_Cat] #1624885
05/26/14 06:18 AM
05/26/14 06:18 AM
cbusters Offline
cbusters  Offline
1" impact from Harbor Freight makes the sleeve start to compress a bit easier. Just don't go to far.
Re: Done! 8 3/4 pinion bearing is kicking my butt. [Re: feets] #1624886
05/26/14 10:49 AM
05/26/14 10:49 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Yep, sounds about right. Until recently, I was a Chrysler tech. and worked on a few diffs during my time.
Fortunately we did not have to deal with a dropout center in a vice since almost all the recent RWD Chrysler products have a Corporate/Dana style housing. Generally we rebuilt them with the vehicle on a lift with the housing still bolted to the car. To crush the sleeve, we used a long pipe over a bar like you did, probably about 6 feet long.
Those things take an unusual amount of force to crush, sometimes required two guys. I will admit to re-using an old crush sleeve once or twice.
Do you have a yoke holding tool? Didn't see you mention it. I would think you would have had to have one to do the job. You put it over the yoke and turn it until the holder handle hits the lift arm or part of the frame, then you pull on your bar. Not sure how to facilitate that operation with the diff in a vice. Maybe have the handle against the floor.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Wow. Just wow. [Re: Squirrel_Cat] #1624887
05/26/14 03:00 PM
05/26/14 03:00 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Well, you see...
It all started out with trying to seat the front bearing so I could check the depth. I got so wound up about the bits not going together that I went a wee bit out of order.
I've only built a couple differentials and this is my first 8 3/4 so I kinda did things out of order.
- Stu Harmon
Re: Wow. Just wow. [Re: feets] #1624888
05/26/14 05:06 PM
05/26/14 05:06 PM
Portage Wisconsin
Lou_Steger Offline
Lou_Steger  Offline
Portage Wisconsin
This is what I made to hold the diff in my vise
Re: Wow. Just wow. [Re: Lou_Steger] #1624889
05/26/14 05:39 PM
05/26/14 05:39 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
The yoke already has flats milled to be held with a tool. I was more inclined to use that than to risk damaging the yoke or u-joint fasteners.
- Stu Harmon
