Re: Father/Son - BB D100 Project
[Re: 85_Ram_4speed]
#1624577
05/26/14 09:23 PM
05/26/14 09:23 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I put 1 on my old 81 Shorty. You could feel the difference in the steering wheel when going around corners.
I am truckless..
[Re: 70Duster440]
#1624578
05/26/14 09:28 PM
05/26/14 09:28 PM
Posts: 15,487 Florida
scratchnfotraction
I can see using one on an off-road 4x4 but how much difference will one really make on a street truck? Curious.
have someone turn the wheels lock to lock at idle,not moving while you watch the how much the box/frame flex under load.
a front sway bar and the brace really firmed up both of my trucks handling in turns and a big improvement for daily driving street duty.
[Re: 70Duster440]
#1624581
05/27/14 01:19 AM
05/27/14 01:19 AM
Posts: 440 Marysville, WA
77ProStreet
Marysville, WA
Going to give Summit Racing's repackaged "whatever" paint a shot on this one (after all my kid will be driving it).
That's exactly the paint I'm using. Actually nice to shoot. Nice finish.
[Re: Mopar2DBone]
#1624582
05/27/14 12:20 PM
05/27/14 12:20 PM
Posts: 5,948 British Columbia
chrisf
British Columbia
Just curious. Will a big block brake booster not work???
still hits. I ran those covers on a low block and I had to unbolt the booster to get the cover off.
[Re: 70Duster440]
#1624584
05/27/14 07:28 PM
05/27/14 07:28 PM
scratchnfotraction
anything else good on those trucks?? the small booster is what it would have with a B or RB enegine with stock late mid 70s smogger VC (not the HP tall penthouse VC) still tight on R&R of VC. on the mid 80s trucks you can go to the 86 3/4 ton vac booster which is a small one that has the alum 2 bolt MC. it has been 'said' that you can hammer on the bigger pancake booster to get it to fit a BB in there... but that always looks like a chebby goober with a BFH has worked on dodge.
[Re: Mopar2DBone]
#1624587
05/28/14 12:53 PM
05/28/14 12:53 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
Bigblock booster is the small diameter. Same that 3/4 tons run and some halftons came with them
[Re: 70Duster440]
#1624588
05/28/14 12:57 PM
05/28/14 12:57 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
There was an '84 Ram with black booster and 2 bolt MC. My understanding is, even with the smaller booster, with (non-factory) tall valve covers you may have to relocate everything up to an inch further away from the engine???
Black booster? For a 440 you just need to swap in a 3/4 ton booster of the same era truck. All 3/4 tons use the small diameter booster which in the 70s was the same used for 440 trucks. the 383/400 B-Blocks can use the big diameter but tall valve covers may be an issue
[Re: 76dodgeboy]
#1624589
05/29/14 03:26 AM
05/29/14 03:26 AM
77ProStreet
Marysville, WA
I've been giving some thought to putting on a hydroboost system instead of a booster. First off its a lot smaller (No valve cover problems) and the brakes are way more responsive, especially if you put discs in the back or upgrade to larger discs all the way around. I had this on my 67 Coronet and it was a night and day difference on stopping performance! [image] [/image]
Re: Progress: Father/Son - BB D100 Project
[Re: 77ProStreet]
#1624594
06/29/14 04:49 AM
06/29/14 04:49 AM
Posts: 1,069 Washington State
70Duster440
Washington State
Dude you have been busy! That's looking great! What are you doing for wheels? I'm selling my cop car wheels and tires.
Thanks - I've got a set of 16x8's like the ones on my Duster but we were thinking of running black steelies on the rear with some Mickey T's or something - but tell me more about what you've got.
