Re: Father/Son - BB D100 Project
[Re: Golden-Arm]
#1624560
05/25/14 12:52 PM
05/25/14 12:52 PM
Posts: 1,739 Grand Forks, ND
Hemi_Ram
Grand Forks, ND
while the front end is blown apart, now would be the best time to add a steering box brace.
Here is a pix of the brace
[Re: 70Duster440]
#1624568
05/26/14 04:22 AM
05/26/14 04:22 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I have a friend with a couple of those braces for sale if you want 1.
I am truckless..
[Re: 340SHORTY]
#1624569
05/26/14 11:47 AM
05/26/14 11:47 AM
Posts: 15,487 Florida
scratchnfotraction
here is a stock plate for the outside of firewall MC area with a stock manual brake rod = rod 7" long. you can get an adjustable rod from mancini. IIRC I made an alum plate used larger bolts bolting it to firerwall and then 2 bolts thru firewall to a alum 2 bolt MC = stock mc from vac brake bosster. IMHO I would use the alum 2 bolt MC over a cast iron MC. I weighed all of my delete and add ons shaving a full 200lbs off the nose of my 88-440truck going manual steer/manual brake/alum intake/alum wp housing/ mimi starter/mini alt/ heater box delete/weld rims weighs in under 3800lbs now with me in it. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 340SHORTY]
#1624572
05/26/14 02:45 PM
05/26/14 02:45 PM
Posts: 1,069 Washington State
70Duster440
Washington State
Thanks - how much?
[Re: scratchnfotraction]
#1624573
05/26/14 02:53 PM
05/26/14 02:53 PM
70Duster440
Washington State
Thanks for the reference, Scratchn' - appreciate it. The Mancini pushrods are apparently gold plated. But they do come with a retainer...
