Re: Old, old magazine article - 727 homemade shift kit [Re: 52savoy] #1623963
05/23/14 10:13 PM
05/23/14 10:13 PM
Tennessee
WyleECoyote Offline OP
Tennessee
Great description, makes sense. Thanks!
Re: Old, old magazine article - 727 homemade shift kit [Re: 1968RR] #1623964
05/24/14 06:21 PM
05/24/14 06:21 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
John - How do you feel about Turbo Action (Cheetah) reverse manual valve bodies (w/o low band apply) for street driven cars?
I'm not a fan of RMVB's on the street, the violent shifts get old after awhile. W/O LBA you need to be conscious of what your right foot's doing in low gear.
Re: Old, old magazine article - 727 homemade shift kit [Re: John_Kunkel] #1623965
12/29/14 02:52 AM
12/29/14 02:52 AM
Tennessee
Tennessee
I finally got up the ole attic and busted out the boxes of magazines and went through my Mopar Action mags and still can't find the mag with the awesome article on this shift kit. Anyone else come across it yet???
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: Old, old magazine article - 727 homemade shift kit [Re: WyleECoyote] #1623966
12/29/14 11:40 AM
12/29/14 11:40 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I have it. It's in my garage. My home computer with the scanner is being repaired, I'll take a picture later. Used it plenty of times. You block the accumulator with a piece of rod adjust the line pressure screw, remove one check ball, #6 if I remember and enlarge one hole in the transfer plate. That's it. I'll look today.
Doug
Re: Old, old magazine article - 727 homemade shift kit [Re: dvw] #1623967
12/29/14 12:42 PM
12/29/14 12:42 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Isn't that what the MP shift improved kit did?
Not that I would know. Been running a 4spd forever.
I remember seeing in the catolog a solid looking steel tube? A ring and spring?
Re: Old, old magazine article - 727 homemade shift kit [Re: Rob C] #1623968
12/30/14 08:42 AM
12/30/14 08:42 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Page one
"I think its got a hemi"
Re: Old, old magazine article - 727 homemade shift kit [Re: gdonovan] #1623969
12/30/14 08:45 AM
12/30/14 08:45 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Page 2
Re: Old, old magazine article - 727 homemade shift kit [Re: gdonovan] #1623970
12/30/14 08:47 AM
12/30/14 08:47 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Page 3
Re: Old, old magazine article - 727 homemade shift kit [Re: gdonovan] #1623971
12/30/14 08:50 AM
12/30/14 08:50 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Page 4
Someone scanned in for me when I asked the question back in 2009, just passing the scans along.
Re: Old, old magazine article - 727 homemade shift kit [Re: gdonovan] #1623972
12/30/14 01:15 PM
12/30/14 01:15 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I guess I've been beaten to it.
Doug
Re: Old, old magazine article - 727 homemade shift kit [Re: dvw] #1623973
12/30/14 01:35 PM
12/30/14 01:35 PM
To confirm, what dia drill bit in #9, is that 9/16"
Re: Old, old magazine article - 727 homemade shift kit [Re: RapidRobert] #1623974
12/30/14 02:19 PM
12/30/14 02:19 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
#9 drill is 0.1960,nowhere close to 9/16"
Re: Old, old magazine article - 727 homemade shift kit [Re: 62maxwgn] #1623975
12/30/14 03:09 PM
12/30/14 03:09 PM
alright, 0.196" thank you. Agreed 9/16" it ain't likely you'd being going that big on a sep plate hole but it sorta looked like 9/16 in the pic so I wanted to clarify
Re: Old, old magazine article - 727 homemade shift kit [Re: RapidRobert] #1623976
12/30/14 03:25 PM
12/30/14 03:25 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
3/16"/.1875"
Re: Old, old magazine article - 727 homemade shift kit [Re: RapidRobert] #1623977
12/30/14 03:26 PM
12/30/14 03:26 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
What mag is that article in ? I have a ton of old mags getting ready to go to the recycle station , I'm tired of moving them...
after reading the first page I have to guess mopar action ??
Re: Old, old magazine article - 727 homemade shift kit [Re: goldmember] #1623978
12/30/14 03:37 PM
12/30/14 03:37 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Robert you confused the issue by putting in #9 instead of saying STEP 9 , as it says to use a
3/16" =.1875"
Not a #9 drill bit , which Bill correctly told you the size. I'm not sure how much a .009 bigger drill is going to affect the desired performance.
The article is confusing about removing a check ball in the upper half , but mentions a cup and spring or ball and spring but must remain ???
It's been a while since I've had a valvebody apart ...
Re: Old, old magazine article - 727 homemade shift kit [Re: JohnRR] #1623979
12/30/14 03:48 PM
12/30/14 03:48 PM
Robert you confused the issue by putting in #9 instead of saying STEP 9 , as it says to use a ..
Alright makes sense now. Thank you! I will tighten up my grammer. I knew me & him weren't on the same page but I couldn't grasp where I was off
Re: Old, old magazine article - 727 homemade shift kit [Re: RapidRobert] #1623980
12/30/14 04:23 PM
12/30/14 04:23 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Enlarging the hole in step #9 only relates to '71 and later...that hole is already larger than 3/16" in the earlier VB's.
And, for the 4000th time, the advice in step #5 to toss the accumulator spring is based on the oldest myth in the Mopar world....DON'T DO IT
And, as I stated earlier in this thread, tossing the check ball in step #7 without rear servo mods is inviting severe overlap on manual 1-2 upshifts.
Re: Old, old magazine article - 727 homemade shift kit [Re: John_Kunkel] #1623981
12/30/14 07:38 PM
12/30/14 07:38 PM
John should I adhere to this for a street automatically upshifting in drive normal vb/trans & what about the slight confusion in step 10 (check ball/spring-cup/spring) which one stays/goes?.
Re: Old, old magazine article - 727 homemade shift kit [Re: RapidRobert] #1623982
12/30/14 07:46 PM
12/30/14 07:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I wouldn't eliminate any check balls in the lower VB (transfer plate). These check balls protect components by limiting fluid flow during application but drop away during release to speed the release.
One exception might be plow trucks in which the check balls delay rapid shifts between Drive and Reverse.
