Page 6 of 8 1 2 3 4 5 6 7 8
Re: 1970 V-code Roadrunner [Re: mopars_1] #1623414
12/28/14 01:50 AM
12/28/14 01:50 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Motor is ready to go in. Just finishing up a few things on the firewall to make things easier. Hopeful for next week.
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: 1970 V-code Roadrunner [Re: mopars_1] #1623415
12/28/14 01:51 AM
12/28/14 01:51 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Painted up the grill and jack assembly (behind) pretty happy with the results.
1937 Plymouth PT50
Re: 1970 V-code Roadrunner [Re: mopars_1] #1623416
12/28/14 01:54 AM
12/28/14 01:54 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Lastly, a close up on the headlight bucket to show contrast in colors. More updates to come, hopefully when the motor is in.
1937 Plymouth PT50
Re: 1970 V-code Roadrunner [Re: mopars_1] #1623417
01/05/15 03:10 PM
01/05/15 03:10 PM
California
mickm Offline
mickm  Offline
California
i've been thinking of doing mine up. what paints did you use, and can you outline the process you did to paint them?
Re: 1970 V-code Roadrunner [Re: mickm] #1623418
01/05/15 09:13 PM
01/05/15 09:13 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Im sure what I did isn't 100% correct, but it looks good IMO. I used Krylon graphite Textured shimmer #2521 and Krylon Silver Textured shimmer #2522 for the paint. pop the trim off, lightly sanded the grill to get the old paint off as much as I could. Then I gave it a bacth in soapy water and let dry. Used adhesion promoter and them primed it. After primer dried, I sprayed the light argent and black first. I did it this way because I figured it would be easier to mask off than the gilled part. When that dried, masked off said areas, and sprayed the graphite. I went front the back side first to assure coverage without getting the paint too heavy and then moved to the front portion. Like I said, it probably isn't the most accurate, but It will look nice in front of the car.
1937 Plymouth PT50
Re: 1970 V-code Roadrunner [Re: mopars_1] #1623419
01/07/15 02:46 PM
01/07/15 02:46 PM
California
mickm Offline
mickm  Offline
California
great, thanks for the recap. may look you up if i get to mine for some more detail...
Re: 1970 V-code Roadrunner [Re: mickm] #1623420
01/07/15 11:12 PM
01/07/15 11:12 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Started putting the motor in. Had to call it quits early. Too hard to heat the shop when its -15 out and 20mph wind.. Get more done tomorrow.
1937 Plymouth PT50
Re: 1970 V-code Roadrunner [Re: mopars_1] #1623421
01/26/15 01:16 PM
01/26/15 01:16 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Sorry havnt posted sooner but the motor and the rest of the driveline is pretty much done. Waiting on the dash cluster to get here and we can wrap up the interior. Still need to bolt on the front clip as well, but everything is moving along nicley.
Btw, the air cleaner lid never got repainted. Had sort of a neat original patina to it so we'll probably leave it
1937 Plymouth PT50
Re: 1970 V-code Roadrunner [Re: mopars_1] #1623422
01/26/15 01:20 PM
01/26/15 01:20 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Dash bezels came back too.
1937 Plymouth PT50
Re: 1970 V-code Roadrunner [Re: mopars_1] #1623423
01/28/15 06:38 PM
01/28/15 06:38 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
Man, things are coming together !!!
Troy
Houston Mopar Connection Club
Re: 1970 V-code Roadrunner [Re: mopars_1] #1623424
01/29/15 04:08 PM
01/29/15 04:08 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Ya things are moving pretty smoothley! If all goes well, should go from start to finish in little over a year.
I know some people on here are going to get their undies in a bundle, but we had a reproduction tag made since the original tag had gotten lost. Its pretty stinking close to the original and we were not trying to deceive anyone by adding codes.
1937 Plymouth PT50
Re: 1970 V-code Roadrunner [Re: mopars_1] #1623425
01/29/15 11:42 PM
01/29/15 11:42 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
for a comparison shot of the original tag...
1937 Plymouth PT50
Re: 1970 V-code Roadrunner [Re: mopars_1] #1623426
01/30/15 12:35 AM
01/30/15 12:35 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Nice options!
Re: 1970 V-code Roadrunner [Re: moparpollack] #1623427
01/30/15 05:12 PM
01/30/15 05:12 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Threw a fender on today..
1937 Plymouth PT50
Re: 1970 V-code Roadrunner [Re: mopars_1] #1623428
01/31/15 06:16 PM
01/31/15 06:16 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Hood bolted on. Passenger fender is going to have to get a little touch up done, otherwise its about as far as we can go for now
1937 Plymouth PT50
Re: 1970 V-code Roadrunner [Re: mopars_1] #1623429
03/05/15 08:55 PM
03/05/15 08:55 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Moving slong. Exhaust is done. Went with tti 2 1/2 and super turbo mufflers. Underside is all done now
1937 Plymouth PT50
Re: 1970 V-code Roadrunner [Re: mopars_1] #1623430
03/05/15 08:59 PM
03/05/15 08:59 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Started putting the dash together as well. Cluster should be done this week and then we can wrape up the dash and subsiquently the rest of the interior. Still waiting on getting the bumpers back from chroming, but it should be finished up in a month
1937 Plymouth PT50
Re: 1970 V-code Roadrunner [Re: mopars_1] #1623431
03/20/15 07:30 PM
03/20/15 07:30 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Dash done and in. Tried to start it today, but wont fire. Trouble shoot tomorrow.
1937 Plymouth PT50
Re: 1970 V-code Roadrunner [Re: mopars_1] #1623432
03/20/15 09:00 PM
03/20/15 09:00 PM
85086
Lil Herman
Lil Herman
85086
Since you did such a good job you can start on mine next.
Re: 1970 V-code Roadrunner [Re: moparpollack] #1623433
03/20/15 11:58 PM
03/20/15 11:58 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
I've always wanted to make it my side job restoring cars for others, but I have to use my dads shop and he doesn't want to get involved. Im looking to buy a house here this next year and my own shop is defiantly on the agenda, so who knows.
1937 Plymouth PT50
