Re: Whats left of a 8 3/4 aluminum center
[Re: Bill_LBSR]
#1620930
05/18/14 07:11 PM
05/18/14 07:11 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Ouch. I get a little nervous with a 4 speed in front of an 8.75 that will see little track time after these posts.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: MoparBilly]
#1620931
05/18/14 07:42 PM
05/18/14 07:42 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Monte, I was being sarcastic!
I am constantly in awe of the advances being made in the heads up classes, and many of us are indebted to those who are willing to spend the sweat, time, effort, and dollars to go that fast. The trickle down from those hard earned lessons is that everyone has the opportunity to step up their program with better, more reliable parts.
If they choose to take off their blinders, and pay attention...
Gotcha Billy..........One of the drag radial cars I am involved heavily with, weighs 2750lbs at our class weight, has a 738 nitrous motor and goes 1.0 60fts on a regular basis. This is a stock suspension type car and has been 4.20s at 175mph in Outlaw Drag Radial trim. Over the years, we have broken EVERYTHING in the driveline. I KNOW what lives and what doesn't in these cars. At this point, our driveline, be it trans, driveshaft, rear end housing or center section, would be right at home in a Pro-Mod, yet we need it in a stock suspension drag radial car to make it live.
We have a 10k trans and converter......A $1200 driveshaft........a $2500 center section........probably about the same in the housing and suspension components, as well as $4000 worth of shocks. But that is what it TAKES to run at that level.
When I first started helping with this car, it was running in the 5.20-5.30 range. So I am acutely aware of what it takes to get to this point and what all the weak spots in between are going to be. I don't make suggestions just to have guys spend a bunch of unnecessary money. I make suggestions based on experience and maybe have them spend the money ONCE, instead of several times.
You always hear the expression "more than one way to skin the cat".......well, when it comes to this stuff, the answer is NO, not really. There is only ONE way to do it and that is RIGHT.
Just this past week, we took $1600 worth of rear shocks off and are trying $2000 worth of NEW rear shocks, in an attempt to make the car even better. It never ends.
Monte
[Re: Monte_Smith]
#1620933
05/18/14 11:31 PM
05/18/14 11:31 PM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
Monte
kind of like my poor boy anology when I was worried about running stock LY rods long ago. If Billy could spray them deep into the nines... mine would be fine
Great read Monte
[Re: J_BODY]
#1620934
05/19/14 10:51 AM
05/19/14 10:51 AM
Posts: 1,893 Spahn Ranch
RMCHRGR
Spahn Ranch
I realize there might not be a definitive answer here but generally speaking, at what performance level does an 8.75 become a ticking time bomb? Seems like if you get to a point where you're putting a cage in you'd want to start considering a Dana or 9"?
Or is it strictly a weight/hp equation?
I'm probably nowhere near that level myself but was just curious. You see enough threads where guys are asking if an 8.75 will live behind such and such combo.
'71 Duster '72 Challenger '17 Ram 1500
[Re: redmist]
#1620937
05/20/14 05:02 AM
05/20/14 05:02 AM
Quicktree
So, uhhhhh.... Say a guy has a full bodied 68 Charger with 500HP... Drag Radials and foot braking. Is it going to Kaboom or what?
You guys got me nervous enough to do the billet front drum in my Copes built 727, now I am nervous about the 8 3/4 rear.
let me put it this way, I wouldn't do it. when it does go boom it will probably take out your tranny. it did on mine at just a little over 500hp E body. and that was not using a drag radial. and good parts in the 83/4.
[Re: Quicktree]
#1620938
05/20/14 06:34 AM
05/20/14 06:34 AM
Posts: 4,071 Mo.
racerx
Mo.
Tree.....Please explain good parts and what weight?
[Re: racerx]
#1620939
05/20/14 07:38 AM
05/20/14 07:38 AM
Quicktree
back braced, billet caps, 3500lbs
[Re: OhioMopar]
#1620940
05/20/14 12:36 PM
05/20/14 12:36 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
I blew up an 8.75 behind a 340 , 4 speed in an A body with greasy B.F. Goodrich tires. There is a reason that Chrysler put out a TSB for the B body 8.75, 3.91 geared cars that came in with blown up rears to replace the 8 3/4 with a 4.10 Dana60 ...
But that has nothing to do with this subject, you can throw thousands of dollars at the 8.75, the weak link is the ring an pinion and there is noting you can do about that.
Monte is right, a series race car needs to go with the strongest rear, drop the big coin once or drop more till you finally get the rear you should have.
[Re: redmist]
#1620941
05/20/14 12:37 PM
05/20/14 12:37 PM
JohnRR
U.S.S.A.
It's not a matter of IF, it's a matter of WHEN ...
I'd be putting a Dana in that car and not look back .
[Re: JohnRR]
#1620942
05/20/14 01:24 PM
05/20/14 01:24 PM
OhioMopar
Mt.Gilead, Ohio
No serious race car for me, but I see a Dana in my future. Hmmmm. I have a 4-speed Dart, as well...
[Re: Airwoofer]
#1620944
05/20/14 02:53 PM
05/20/14 02:53 PM
dogdays
That's pure baloney. The diameter of the pinion depends on just three things: 1. Ring gear diameter 2. Gear ratio 3. Where the pinion is with respect to the ring gear.
If you want an 8 3/4 with a larger diameter pinion, get a 2.76 gearset.
If you want more teeth to engage, get a Ford 9", the pinion is lower on the ring gear.
Otherwise, you're stuck with how Mopar engineers designed it. They put the pinion higher to increase efficiency. They decided on 8 3/4 as a good diameter to provide adequate strength, not being soothsayers (who could see people hooking 600lb-ft engines to the front and with 3500 lb on two 12" wide tires on the back.)
The REASON the gear teeth break is the pinion and ring gear are pushing away from each other. The farther apart they go, the more the moment on the gear tooth root increases. Voila! Teeth break.
There's no magic involved. Ford's 9" has a slightly larger ring gear but the major advantage is the pinion is supported on both ends. This is also the 9"s biggest disadvantage as well, there's no room for a decent limited slip because it'd run into the pinion support.
Trade-offs, trade-offs.......
R.
[Re: dogdays]
#1620945
05/20/14 03:06 PM
05/20/14 03:06 PM
Guitar Jones
The 9" in aftermarket form is a stout piece, no doubt but you can't use any Ford parts in it or it's just another junker. The reason the pinion is supported on both ends is because the Ford engineers didn't design enough space between the front two pinion bearings. So they inadvertently designed a rear that drag racers would like because of the third bearing. Even a blind squirrel finds a nut once in awhile. As for the 8.75, I have one in my car with the AL center section but I use only pro gears in it as I've broken a couple street gears and yes I leave on a transbrake. The drawback is the pro gear is only available in one ratio, 4.86:1, so I tend to build my car around that rather than the other way around. I used the 8.75 because that was what I had at the time. If I ever explode it though I'll probably replace it with a Dana, I don't need the 9" or the expense of it.
[Re: dogdays]
#1620946
05/20/14 03:12 PM
05/20/14 03:12 PM
Posts: 22,696 Bitopia
jcc
Bitopia
R.
I agree 98%, but not largely mentioned is, the lower ratios heading towards 2.76 are slightly stronger then the the higher ratios, put your pushing apart concept is the heart of the problem, and every design has a power limit.
And a 2.76 will not fit a stock Alum 8.75.
[Re: Guitar Jones]
#1620947
05/20/14 03:31 PM
05/20/14 03:31 PM
Monte_Smith
North Alabama
Inaccurate statement right here........... Ford offered a FACTORY rear with the heavy duty housing, 31 spline axles, Detroit Locker and a NODULAR center. Probably as stout of a factory rear that was offered by anybody. A nodular center is a nodular center, so a good pinion support on THAT stock case would be as good as an aftermarket. So saying ALL factory Ford centers were junk is a fallacy.
Now, while the chances of finding a factory nodular center in a junkyard these days would be next to impossible, it used to be fairly easy. Same as it used to be fairly easy to find track pack Danas in junkyards.
I find your description of the engineering that went into the 9" interesting. So I take it you were THERE and know they went "oh sh&t, we messed up, we need to add a bearing on the pinion"............LOL!!!
PLUS...........Lets take ALL this back and forth to the post that STARTED this thread........The car in question is a DRAG RADIAL car that has the potential to be FAST. THIS car, needs a 9".....end of discussion. What OTHERS may need is of no consequence in the discussion of THIS car
Monte
[Re: OhioMopar]
#1620948
05/20/14 03:43 PM
05/20/14 03:43 PM
JohnRR
U.S.S.A.
I don't, you won't find one that bolts in for 50 bucks ...
