'68 woodgrain steering wheel, restore vs. repop? #1620550
05/16/14 12:50 AM
05/16/14 12:50 AM
Houston, Texas
Slant6pak Offline OP
Houston, Texas
Hey guys,
I'm searching for a woodgrain steering wheel to replace the green taxi cab wheel in my 1968 Coronet.
I've been trying to find a decent original for sale, but even ones that are IMO, pretty rough seem to go for decent money.
I see there are repop wheels available for around $600, are they any good?
Who would you use to restore an original and what is the approximate cost?
2016 Challenger Scat Pack Shaker smile
1000 ci Brass Era Speedster project
Re: '68 woodgrain steering wheel, restore vs. repop? [Re: Slant6pak] #1620551
05/16/14 03:41 AM
05/16/14 03:41 AM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
I have heard good things about steering wheels restored by http://garyssteeringwheel.com/ the aftermarket ones that I have read about all have spokes that are way shiny compared to stock.
Re: '68 woodgrain steering wheel, restore vs. repop? [Re: wesgtx440] #1620552
05/16/14 08:28 AM
05/16/14 08:28 AM
Nice used or restored woodgrain wheels are not cheap or plentiful. Expect to have to pay $500 - $800 for a real nice one with the center cap and goods. "Restored" ones with bondo'd up handles, sandpapered grain and spray painted spokes generally take a while to sell for around $500. Repops would be my absolute last resort as they have chrome plated spokes and a handle with drawn on grain that has no texture to it.
Wait for a nice used wheel to pop up unless the other two options dont bother you.
Re: '68 woodgrain steering wheel, restore vs. repop? [Re: ] #1620553
05/17/14 12:30 PM
05/17/14 12:30 PM
Houston, Texas
Houston, Texas
I seem to remember that when a wheel is restored, that nothing can be done with the spokes if they are flaking/pitted.
Is that correct?
Re: '68 woodgrain steering wheel, restore vs. repop? [Re: Slant6pak] #1620554
05/17/14 01:34 PM
05/17/14 01:34 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
Had two restored ,they were powder coated silver and glossed looks great...PAT
Re: '68 woodgrain steering wheel, restore vs. repop? [Re: Slant6pak] #1620555
05/17/14 02:46 PM
05/17/14 02:46 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
IMO,,, find an original and have it redone.
Talk to Dave ,,aka plumbeeper
http://www.rimblowsteeringwheels.com/
Re: '68 woodgrain steering wheel, restore vs. repop? [Re: Slant6pak] #1620556
05/19/14 02:26 AM
05/19/14 02:26 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is that correct?
Doug in Canada was able to have the spokes redone .
Then there is always NOS ...
Re: '68 woodgrain steering wheel, restore vs. repop? [Re: Slant6pak] #1620557
05/19/14 11:43 AM
05/19/14 11:43 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Several alternatives, restore the wheel yourself if you have the skill sets, buy NOS, or extremely nice used, buy junk have it restored, or buy repro, and if you want it to look "original" send it out to several of the wheel restorers, they can scotchbrite the chrome down to look like the dull nickel sheen it should have, and they can "cut" a new grain and finish it accordingly...depending on your choice, your going to spend several hundred to a G note to get what you desire
Re: '68 woodgrain steering wheel, restore vs. repop? [Re: DAYCLONA] #1620558
05/20/14 01:22 PM
05/20/14 01:22 PM
Houston, Texas
Houston, Texas
Are there several versions of the wheel?
I seen one that the rim was all wood grain, one that had a chrome band on the outside of the rim, and one that looked like woodgrain on the front of the rim, but behind the chrome band it looked black.
Which is correct for a '68 car?
Re: '68 woodgrain steering wheel, restore vs. repop? [Re: Slant6pak] #1620559
05/20/14 02:15 PM
05/20/14 02:15 PM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
Correct for 68 would be wood grain front and back with a stainless steel band around the outside.
Re: '68 woodgrain steering wheel, restore vs. repop? [Re: Slant6pak] #1620560
05/20/14 02:23 PM
05/20/14 02:23 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Correct for a 68 RR is woodgrain front and back, with stainless steel bands on the outside and inside of the wheels rim separating the front from the back, basically splitting the steering wheel in half, so to speak, the B body woodgrain wheels are basically the same, with the exception of the 70 B body models, which have a different woodgrain color, as well as 3 small holes drilled into the spokes near the horn center to mount the steering column filler ring needed because in 70 the ignition switch was in the column, making the column larger in diameter, so the 70 wheels were modified with an adapter ring to cover the larger opening of the 70 columns
mike
Here's a 68 RR woodgrain wheel below
Re: '68 woodgrain steering wheel, restore vs. repop? [Re: Slant6pak] #1620561
05/20/14 02:31 PM
05/20/14 02:31 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Chase,
go to this link, if your thinking of having a repro wheel redone to look like original www.steeringwheelsbymike.com then click on "wheels album #1" to see his conversions of the repro wheels
Mike
Re: '68 woodgrain steering wheel, restore vs. repop? [Re: DAYCLONA] #1620562
05/20/14 02:50 PM
05/20/14 02:50 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
I bought two off a moparts member earlier this year. He had three, all from those drivers ed training module things. apparently got a hell of a deal seeing these prices
I don't know what year they are though. Still have to find the center pieces for them though.
Re: '68 woodgrain steering wheel, restore vs. repop? [Re: Slant6pak] #1620563
05/23/14 10:47 PM
05/23/14 10:47 PM
CO
Redbird Offline
Redbird  Offline
CO
There were 2 different woodgrain steering wheels from 1969. Most all of them are not drilled for the 3 holes.
There are some very late model 1969 wheels drilled for the 3 holes. The serial numbers of the 3 holed wheels are 90 degrees in orientation from the earlier wheels.
I am not sure if these 3 holed wheels could have been used on early 1970 cars.
Re: '68 woodgrain steering wheel, restore vs. repop? [Re: Redbird] #1620564
05/23/14 11:08 PM
05/23/14 11:08 PM
new york usa
P
P
new york usa
Yes, for 1970 b body's the ignition key was moved from the dash to the steering column creating the need for the plastic trim ring used to fill the gap created by the larger diameter column to accommodate the ignition key now in the steering column...pat ( 68 -69 no three holes) ( 3 holes 1970 applications )
Re: '68 woodgrain steering wheel, restore vs. repop? [Re: Redbird] #1620565
05/25/14 02:04 PM
05/25/14 02:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The 3 holes in the wheel were for the ring that was added to a 70 wheel because of the column change so I don't know why that wheel would not have been used on an early 70 car??
Re: '68 woodgrain steering wheel, restore vs. repop? [Re: JohnRR] #1620566
07/27/14 12:38 AM
07/27/14 12:38 AM
Iowa - a member of the rustbel...
Birdturd Offline
Birdturd  Offline
THis is a consideration of mine on this, I purchased a wheel that needs restoration, I still need to get an estimate but I'm strongly considering taking the wheel to a woodworker/cabinet maker in town and having some actual wood put on it.
Re: '68 woodgrain steering wheel, restore vs. repop? [Re: DAYCLONA] #1620567
07/27/14 02:07 AM
07/27/14 02:07 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
I need one of these too.
Since I don't have one, I can't confirm how the stainless bands were made, but I think those are inlaid?
So if you add real wood, you need a plan to replicate the stainless bands.
But real wood could be really nice. Please post photos and discuss if you get it done.
