Re: 727 input shaft question... [Re: Cab_Burge] #1620274
05/16/14 05:59 AM
05/16/14 05:59 AM
Arizona
Chris'sBarracuda Offline
Arizona
Actually you really need a GLIDE!!!
900 HP at 3100 lbs, I would look at at a Proflyte
Mine is just at 3000# plus 900+ hp. and has a GLIDE..
Me likes it..
Best thing I ever did was to trade my $4000.00+ Pro Trans Super Duper Torqueflight back to Dave Smith for a Mikes Glide..
That was back in 1994.. The results were immediate..
You will notice the Pro Trans is covered up..
3rd race with the Glide and got a Wally.. Wound up #2 in Division 5..
And I'm not bashing Pro Trans at all.. Best T/F builders in the business.. Dave is the absolute best..
The Glide has just worked better for me..
Chris..
Re: 727 input shaft question... [Re: Jeepmon] #1620275
05/16/14 11:59 AM
05/16/14 11:59 AM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
Should have bought a glide
Like you said... "kicking and screaming"
Ask Dave Hall how well his Mikes Glide worked for him. It broke in less than 10 passes. Nothing is bullet proof.
Re: 727 input shaft question... [Re: WheelsUp73] #1620276
05/16/14 12:48 PM
05/16/14 12:48 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
It really doesnt matter.. PG or TF.. I've broken both of them...
Not sure if I should bragging or hiding in shame...
Re: 727 input shaft question... [Re: WheelsUp73] #1620277
05/20/14 01:08 PM
05/20/14 01:08 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
what's the story on the 300 shaft ?
and does it fit a 727 ?
Re: 727 input shaft question... [Re: a493demon] #1620278
05/20/14 01:26 PM
05/20/14 01:26 PM
dogdays Offline
dogdays  Offline
300M is the type of steel. Tensile strength, properly heat treated, is 300,000psi.
"300M is a low alloy, vacuum melted, steel of very high strength. Essentially it is a modified AISI 4340 steel with silicon, vanadium and slightly more carbon and molybdenum. 300M has a very good combination of strength at 1930–2100 MPa (280-305 ksi), toughness, fatigue strength and good ductility. It is a through hardening alloy."
R.
Re: 727 input shaft question... [Re: dogdays] #1620279
05/20/14 03:04 PM
05/20/14 03:04 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
When I still ran a 727 in my own car, it got to the point that the alum front planet hubs would last about 5 runs. Went to the steel front hub from a truck trans. Second pass after THAT fix, it broke the input shaft. Ok, maybe it was weakened. Put another input in there and it lasted 3 passes. Ponied up for the high dollar input shaft and then it broke the OUTPUT shaft. That was the LAST run my car EVER made with a 727
Monte
Re: 727 input shaft question... [Re: Monte_Smith] #1620280
05/20/14 04:53 PM
05/20/14 04:53 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
You were almost there Monte. That 300m output shaft would have been cheaper then that whole Chevy trans.
Re: 727 input shaft question... [Re: dizuster] #1620281
05/20/14 05:00 PM
05/20/14 05:00 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Had enough in that damn 727 to have built 3 good glides.........Plus, couldn't get the converter I wanted, brakes were slow, clean neutral was an issue, hated the blanket, plus it was freaking HEAVY. I FINALLY snapped out of it........LOL!!!
Monte
