Re: gear lube or atf in a 833 4 speed [Re: Ramrod39] #1619830
05/14/14 03:24 AM
05/14/14 03:24 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
the Passon shifts great in mine and BTW its a fairly thin oil, my guess is about a 5w/30 in viscosity. maybe Passon or Brewers can chime in but i remember one of them saying no to atf for a street driven car.
Re: gear lube or atf in a 833 4 speed [Re: ditchdrift] #1619831
05/14/14 09:24 AM
05/14/14 09:24 AM
an8sec70cuda Offline
syncromesh fluid. best working fluid i have found.
Pennzoil Syncromesh. Have it in my dad's 440-6 road runner...works great.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: gear lube or atf in a 833 4 speed [Re: bigblockbryan] #1619832
05/14/14 09:43 AM
05/14/14 09:43 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Initial fill should be ATF.
Drive it.
Check for leaks.
Drain, refill with heavier lube of choice.
Re: gear lube or atf in a 833 4 speed [Re: Commando1] #1619833
05/14/14 01:48 PM
05/14/14 01:48 PM
dogdays Offline
dogdays  Offline
BTW, no such thing as SAE 140 motor oil.
R.
Re: gear lube or atf in a 833 4 speed [Re: kentj340] #1619834
05/14/14 04:22 PM
05/14/14 04:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Isn't the factory service manual the authority on this?
Obviously, not to everybody.
