Stage VI users #1618581
05/10/14 10:48 PM
05/10/14 10:48 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
just checking in with members who use the Mopar Stage VI heads.
have you had any issues with the valve stem design how the spring seems to be floating in oil & the valve stem seal has to be perfect or it leaks down the stem & gets sucked into the intake?
i've had a few sets of Indy heads but i now have a set of Stage VI's that came on an engine i bought. i had an issue with the RH bank smoking a bit & traced to the valve stem seals had come loose which allowed oil to leak down the intake valve stem.
to fix it i got creative with the die grinder & reshaped the area around the valve spring seats so the oil could escape quicker. has anybody else done this? i'm kinda at a loss to understand why someone would design a head like this, but i'm sure what i've done will reduce the chances of a recurring failure. also everytime i removed the valve cover, oil would instantly dribble down onto the headers, what were they thinking?
they started looking like this...
Re: Stage VI users [Re: rebel] #1618582
05/10/14 10:49 PM
05/10/14 10:49 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
bit of a grind later they looked like this...
Re: Stage VI users [Re: rebel] #1618583
05/10/14 10:50 PM
05/10/14 10:50 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
with a bit of a tidy n some polishing they finished up like this.,,,
Re: Stage VI users [Re: rebel] #1618584
05/10/14 11:17 PM
05/10/14 11:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
We have to do the same thing on the SB W-5 heads
Re: Stage VI users [Re: MR_P_BODY] #1618585
05/10/14 11:23 PM
05/10/14 11:23 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
did they have the same idiot designer?
Re: Stage VI users [Re: rebel] #1618586
05/10/14 11:41 PM
05/10/14 11:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep
Re: Stage VI users [Re: MR_P_BODY] #1618587
05/11/14 12:33 AM
05/11/14 12:33 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
the castings were designed for a longer valve. the machining to make them fit standard length valves is where the problems start to happen. Pretty much anyone assembling these heads does that before they ever make it onto an engine. Whoever you got it from should have known better. The raw casting has much more potential than the machined version.
Re: Stage VI users [Re: TRENDZ] #1618588
05/11/14 04:48 AM
05/11/14 04:48 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
care to share any other tips with these heads before i reassemble them?
i guy i bought the engine from didn't come across as the brightest crayon in the box but the guy who assembled this engine was a total muppet. i'm learning as i go but i'm more familia with Indy heads, not these strangely engineered items.
Re: Stage VI users [Re: rebel] #1618589
05/11/14 08:48 AM
05/11/14 08:48 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
Lap the valves, it will show up any faults with seats/valves not being concentric. My
Re: Stage VI users [Re: Oyvind Mopar] #1618590
05/11/14 09:13 AM
05/11/14 09:13 AM
Arizona
Chris'sBarracuda Offline
Arizona
I had a set before my B1's.
They were done by Don Studley.
Precision Cylinder Head in So. Cal. (R.I.P. DON)
Don was an awesome cylinder head guy, especially Mopars.
When I took him my set of Stage 6's he just laughed and said
" What do you want me to do with this sh!t"??
I asked him to do his best..
Well, Don did.. Cussing all the way through them..
He put longer valves in them so the spring pockets weren't so deep . He also cut drain backs in all of them to fight your same problem.
Don got 360 cfm out of these on
his stingy bench.
My ET's were in line with the possible HP with these heads.
9.20's @ 144 in Phoenix at 3000# and a glide.
As one poster said. These heads can be made to work well in the right hands.
He also cut the rocker stands down to use Max Wedge style aluminum blocks to get the best geometry..
These were Max Wedge ports.. 502" low deck.
Wish I still had them and Don was still here too.
Chris..
Re: Stage VI users [Re: Chris'sBarracuda] #1618591
05/11/14 02:25 PM
05/11/14 02:25 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
hummm next time I have the valve covers off I'll have to look and see if mine were cleaned up like that. However I can let the car sit for weeks/months and I get no "crop dusting" Looks nice
Coming soon!!!!
Re: Stage VI users [Re: Mr.Yuck] #1618592
05/12/14 02:45 AM
05/12/14 02:45 AM
Ontario Canada
Hutch Offline
Hutch  Offline
Ontario Canada
I cut several notches in mine which helps to get the oil from the pocket but the entire head still has a bad tendency to fill up with oil and smoke at times. Next time its apart , some external drain hoses or maybe even a dry sump system will be installed to control it.
Hutch
Re: Stage VI users [Re: Hutch] #1618593
05/12/14 03:21 PM
05/12/14 03:21 PM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
Don't mean to hijack, but anyone have any chamber pics for their stage 6 heads?
Thanks, Jeff
Re: Stage VI users [Re: TheBlackCar] #1618594
05/12/14 06:08 PM
05/12/14 06:08 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I just ground notches into the pockets so the oil drains out. I have never had any issues. These heads seem to be working ok for me. I am happy with the performance.
67' charger 499 RB 10.57 at 127
Re: Stage VI users [Re: rebel] #1618595
05/12/14 10:02 PM
05/12/14 10:02 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
don't try to run harland/sharp rockers on them. No standard valve cover will fit over them.
Re: Stage VI users [Re: TRENDZ] #1618596
05/12/14 10:39 PM
05/12/14 10:39 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Harland Sharps here, no problem with these covers
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Stage VI users [Re: TheBlackCar] #1618597
05/12/14 11:15 PM
05/12/14 11:15 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Thanks, Jeff
Mine look like this. They will definitely receive some attention before seeing service.
Re: Stage VI users [Re: Bill MeLater] #1618598
05/12/14 11:17 PM
05/12/14 11:17 PM
Wisconsin USA
Wisconsin USA
By the way they are max wedge. Here's the casting number.
Re: Stage VI users [Re: Bill MeLater] #1618599
05/13/14 12:26 AM
05/13/14 12:26 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: Stage VI users [Re: BloFish] #1618600
05/13/14 12:39 AM
05/13/14 12:39 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Yep. Had to use fabricated covers with mine to. Standard stamped or cast ones wont fit.
