A good gauge shop can rebuild or replace as needed. Even after rebuild, the rally gauge is slow responding as in quite a few seconds (at least mine is).
I ran a mechanical gauge immediately after building my BB. It would show some pressure cranking and almost instantly jump to high pressure after start with cold oil. The rally gauge is sloow. It shows no pressure on crank and slowly moves to high pressure after start. I'm thinking of adding a light or a faster acting added gauge to warn me of momentary low OP situations.
