Re: why isn' there much written about 81to 90 2wd truck
[Re: pokey1]
#16163
02/22/06 08:57 PM
02/22/06 08:57 PM
Posts: 1,652 Amarillo, Tx
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
84 D150 440/727 79 /6 swb D150 1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
[Re: Webster]
#16165
02/23/06 12:38 AM
02/23/06 12:38 AM
Posts: 478 Utah
pokey1
mopar addict
mopar addict
Utah
[Re: pokey1]
#16166
02/23/06 04:34 AM
02/23/06 04:34 AM
I hope ya feel better Old Goat.
#16167
02/23/06 04:43 AM
02/23/06 04:43 AM
Congratulations Pokey!!!! Hey let's here more about this truck smiley and then some stuff.
[Re: old_goat]
#16170
02/24/06 12:20 AM
02/24/06 12:20 AM
Posts: 478 Utah
pokey1
mopar addict
mopar addict
Utah
[Re: pokey1]
#16171
02/24/06 12:54 AM
02/24/06 12:54 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
Ok I have to jump on this Band wagon also here is a pic of my 89 4x2 shortie was a v6 5sp now has a 360 & a NV3500 5sp , needs to be finshed , if it doesn't sell I 'll get to it .
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: ric3xrt]
#16172
02/24/06 12:56 AM
02/24/06 12:56 AM
ric3xrt
Trumbauersville PA
engine shot, with the summit shortied headers.
[Re: pokey1]
#16174
02/24/06 01:12 AM
02/24/06 01:12 AM
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
Hey now!... I am a Capricorn....the goat! Or see attached...They always said I was the "Black sheep"
[Re: ric3xrt]
#16175
02/24/06 11:37 AM
02/24/06 11:37 AM
That looks just fine.
...and still no truck smiley.
#16176
02/24/06 11:21 PM
02/24/06 11:21 PM
Posts: 478 Utah
pokey1
mopar addict
mopar addict
Utah
[Re: pokey1]
#16177
02/24/06 11:48 PM
02/24/06 11:48 PM
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
geez Pokey......astrology...sign.... and yeah, I do have too many projects. I would be a circus act if I really were, LOL
[Re: old_goat]
#16178
02/25/06 02:21 AM
02/25/06 02:21 AM
Posts: 2,590 Piqua, Ohio
dodgeram440
Piqua, Ohio
Hey guys, I have a problem with my truck maybe someone can help me with. Everytime I step on the gas, it bogs down...bad. Sometimes it pops back thru the carb, sometimes it even dies. If I ease into it, it's not to bad. It doesn't matter if it's cold or warm. I've rebuilt the carb and it didn't improve at all. I'm going to replace the timing chain this weekend, but I'm not sure that will fix it. It has this computer box under the left fender that I assume only controls the ignition because that is where the vacuum advance is at. I've thought about putting in a regular electronic ignition, but I'm not sure how to wire it and eliminate that computer. Also, I've searched all over this truck and I can't find a ballast resistor or the control module, so I'm assuming (again) that they aren't needed with this setup. I just want to be able to step on the gas and go like a Dodge is supposed to go. BTW, this is an 86 with a 318 2bbl. Thanks for any help.
[Re: dodgeram440]
#16179
02/25/06 04:41 AM
02/25/06 04:41 AM
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
sounds like a possible vaccuum leak....it is a lean burn engine....the dist has no advance mechanisim....the com is in the air cleaner.... I would check the power brake line, all vac lines for that matter....go from there. A mopar electronic distributor with vac. advance will help all around tho. wiring can be found in the tech pages.... Did it start doin this all at once?
[Re: pokey1]
#16181
02/25/06 03:31 PM
02/25/06 03:31 PM
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
Years ago , in the Ozark mountains, where I was born, That would make me an "Old Mountain Goat".... .... oh you were referrin to the vacuum problem, lol
