Re: Splash-zone epoxy test. coated and un-coated
[Re: pittsburghracer]
#1617186
08/08/14 05:11 PM
08/08/14 05:11 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I can't find it right now but if you do some playing around with this website you may come up with the proper coating. http://www.coleparmer.com/Chemical-Resis...CFcUDOgodxgIADA
#1617187
08/08/14 11:57 PM
08/08/14 11:57 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Thanks John, I will check out your link. Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#2084898
06/02/16 11:04 PM
06/02/16 11:04 PM
Posts: 52,972 Romeo MI
MR_P_BODY
All you guys used it on gas or alky type gas.. what about oil.. anyone tried any testing on oil.. I want to glue in a brass tube to alum.. just to make sure it seals
[Re: MR_P_BODY]
#2085113
06/03/16 11:28 AM
06/03/16 11:28 AM
Posts: 22,697 Bitopia
jcc
Bitopia
I'm currently trying epoxy #526n, its two part, available in black, approx $140/pint, requires two post application cures, 2hrs @200F, 2-16hrs @325F. they quote good chemical/temp resistant specs. It is tough stuff. http://www.aremco.com/high-performance-epoxies/
#2085252
06/03/16 02:47 PM
06/03/16 02:47 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
I can tell you that the Splash Zone on my heads with E85 only lasted about a year before the majority of it came off at the pushrod pinch. It wasn't any better then JB weld was. I just tried it again, but this time added a top coat of KBS Gold Standard Tank Sealer. http://www.summitracing.com/parts/kco-5200It is supposed to be E85 resistant, so we'll see how this goes....
#2085270
06/03/16 03:21 PM
06/03/16 03:21 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Hysol Aerospace Products EA934NA, solvent proof, has aluminum powder in the base.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
#2085279
06/03/16 03:36 PM
06/03/16 03:36 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
I tried this with E-85 and normal fuel system parts in jars of it and after 10 years in the jars none of the items ever changed, the fuel didn't hardly change smell yet (a little but not much). I did not try any kind of epoxy but I have a steel fuel line, a 1968 piece of rubber line, some brass fittings, holley power valve thermo-quad plastic chunk and a piece of modern EFI line, nothing changed in 10 years. People say "well if you get water in it then it is corrosive" I never tried putting water in my fuel and I try to keep my fuel tanks sealed.
