Re: 1971 Cuda post jack plating?
[Re: floyd]
#1616684
07/28/14 07:01 PM
07/28/14 07:01 PM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
Has anyone come up with a good way to get the jack mechanism off (and back on) the tube so it can be replated? Thanks [/quote
[Re: floyd]
#1616686
07/29/14 02:31 AM
07/29/14 02:31 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
The posts have a dimple at each end that keep the mechanism from coming off. Flatten the dimple on one end just enough to allow the mechanism to slip off. After painting the mechanism and plating the post, reassemble and re-dimple.
And, if you check the mechanism carefully, you will see it was dip painted, not spray painted.
[Re: 44D6PAKCUDA]
#1616691
07/30/14 01:39 PM
07/30/14 01:39 PM
Posts: 4,115 MD
floyd
MD
