Re: Hood scoop pressure too much on big end. SSAH Type [Re: sshemi] #1616533
05/06/14 10:12 PM
05/06/14 10:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sorry to highjack but what gains can be expected going from a stock Hood to a glass with hemi scoop on a -68 barracuda?
Anyone ever did a somewhat fair back to back test on this?
You should see .2 gain if sealed... maybe a bit more
depending on the current tune up
Re: Hood scoop pressure too much on big end. SSAH Type [Re: Thumperdart] #1616534
05/06/14 11:10 PM
05/06/14 11:10 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Drill holes in the back of the scoop..............
That's what I did
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Hood scoop pressure too much on big end. SSAH Type [Re: BloFish] #1616535
05/06/14 11:40 PM
05/06/14 11:40 PM
OHIO
THE GLASS MAN Offline
OHIO
I make these hoods and scoops and have 2 of the 68 Hemi Cudas, one with the pan mated to the hood and the other completely open. I actually leave the pin off the center of the rear on both cars to let some of the pressure out of the engine compartment. Sure, it comes up about 2 inches on top end , but neither one has cracked or broke in 20 years. Fiberglass is very forgiving.
Re: Hood scoop pressure too much on big end. SSAH Type [Re: MR_P_BODY] #1616536
05/07/14 03:23 AM
05/07/14 03:23 AM
sweden
sshemi Offline
sshemi  Offline
sweden
Wow. I didnt think it would be that much.
Guess im gonna start saving some money.
Re: Hood scoop pressure too much on big end. SSAH Type [Re: sshemi] #1616537
05/07/14 10:52 PM
05/07/14 10:52 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I wouldn't BANK on it netting you 2/10ths. As a matter of fact if the carb is not too close to the hood now with NO scoop, adding one may not help it at all. Most factory scoops were not put on because they worked. Most were for strictly looks or air cleaner clearance.
Monte
Re: Hood scoop pressure too much on big end. SSAH Type [Re: Monte_Smith] #1616538
05/08/14 12:25 AM
05/08/14 12:25 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My Dart has a 6 pack scoop on it, the top of the carb is about 6" from the top of the scoop. In the 1/8 it was off nearly .1 in a,b,a testing. It wasn't happy without the pan sealed to the hood.
Re: Hood scoop pressure too much on big end. SSAH Type [Re: GTSDave] #1616539
05/12/14 10:47 PM
05/12/14 10:47 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Here's what I did to mine.
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Hood scoop pressure too much on big end. SSAH Type [Re: BloFish] #1616540
05/13/14 02:03 AM
05/13/14 02:03 AM
Mo.
racerx Offline
racerx  Offline
Mo.
^^^Did this help any^^^
Re: Hood scoop pressure too much on big end. SSAH Type [Re: Monte_Smith] #1616541
05/13/14 02:10 AM
05/13/14 02:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Monte
This is very true with those low style factory scoops..
most of them are JUNK but the mopar people HAVE to
have them.... they arent up in the clean air flow
Re: Hood scoop pressure too much on big end. SSAH Type [Re: MR_P_BODY] #1616542
05/13/14 05:36 AM
05/13/14 05:36 AM
sweden
sshemi Offline
sshemi  Offline
sweden
My carb is very close to the Hood now.
I even need to use a drop base with a 2,5" filter!
I wonder if cold air is just as important with E85 as with gas?
Re: Hood scoop pressure too much on big end. SSAH Type [Re: racerx] #1616543
05/13/14 10:09 AM
05/13/14 10:09 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
It did for me. It went from rising 2", to only 1/2".
And I do not have a pan to seal the carb.
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Hood scoop pressure too much on big end. SSAH Type [Re: sshemi] #1616544
05/13/14 10:24 AM
05/13/14 10:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes it is as important... air is air.. if its already
expanded you dont fit as much in
Re: Hood scoop pressure too much on big end. SSAH Type [Re: MR_P_BODY] #1616545
05/13/14 11:11 AM
05/13/14 11:11 AM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Just thinking out loud but wouldn't the hood try to raise because of fast moving air (low pressure) above, than the slow moving air under the hood (high pressure)?
Like a convertible top
