Re: Hood scoop pressure too much on big end. SSAH Type
[Re: sshemi]
#1616533
05/06/14 10:12 PM
05/06/14 10:12 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Sorry to highjack but what gains can be expected going from a stock Hood to a glass with hemi scoop on a -68 barracuda? Anyone ever did a somewhat fair back to back test on this?
You should see .2 gain if sealed... maybe a bit more depending on the current tune up
[Re: MR_P_BODY]
#1616536
05/07/14 03:23 AM
05/07/14 03:23 AM
Posts: 2,128 sweden
sshemi
sweden
Wow. I didnt think it would be that much. Guess im gonna start saving some money.
[Re: sshemi]
#1616537
05/07/14 10:52 PM
05/07/14 10:52 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
I wouldn't BANK on it netting you 2/10ths. As a matter of fact if the carb is not too close to the hood now with NO scoop, adding one may not help it at all. Most factory scoops were not put on because they worked. Most were for strictly looks or air cleaner clearance.
Monte
[Re: GTSDave]
#1616539
05/12/14 10:47 PM
05/12/14 10:47 PM
Posts: 16,504 On the run…
BloFish
On the run…
Here's what I did to mine.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: Monte_Smith]
#1616541
05/13/14 02:10 AM
05/13/14 02:10 AM
MR_P_BODY
Monte
This is very true with those low style factory scoops.. most of them are JUNK but the mopar people HAVE to have them.... they arent up in the clean air flow
[Re: MR_P_BODY]
#1616542
05/13/14 05:36 AM
05/13/14 05:36 AM
Posts: 2,128 sweden
sshemi
sweden
My carb is very close to the Hood now. I even need to use a drop base with a 2,5" filter! I wonder if cold air is just as important with E85 as with gas?
[Re: sshemi]
#1616544
05/13/14 10:24 AM
05/13/14 10:24 AM
MR_P_BODY
Yes it is as important... air is air.. if its already expanded you dont fit as much in
[Re: MR_P_BODY]
#1616545
05/13/14 11:11 AM
05/13/14 11:11 AM
Posts: 8,307 fredericksburg,va
cudaman1969
fredericksburg,va
Just thinking out loud but wouldn't the hood try to raise because of fast moving air (low pressure) above, than the slow moving air under the hood (high pressure)? Like a convertible top
