Re: Initial hard to crank over but then turns over good...? [Re: MR_P_BODY] #1616405
05/06/14 03:58 PM
05/06/14 03:58 PM
Houston, Texas
TheOtherDodge Offline OP
Houston, Texas
Since I drove the truck to work today (since it is a street truck, 22 miles from work to home), I went out to get a video of it. It started like a champ! I had the battery on a charger last night so I am begining to wonder if I need a stronger battery or alternator?
Re: Initial hard to crank over but then turns over good...? [Re: TheOtherDodge] #1616406
05/06/14 04:05 PM
05/06/14 04:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You should check the cranking power of the battery..
load test... whats the output of the alt
Re: Initial hard to crank over but then turns over good...? [Re: TheOtherDodge] #1616407
05/06/14 04:09 PM
05/06/14 04:09 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I have a stock one wire 60 amp chevy alternator on my Duster and it will keep up on MOST race days but i usually don't go a lot of rounds like some guys. About every other week i have to charge it during the week or it will drop to a voltage level where the alternator isn't energized enough to charge the battery and actually starts discharging it.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Initial hard to crank over but then turns over good...? [Re: pittsburghracer] #1616408
05/06/14 04:21 PM
05/06/14 04:21 PM
Houston, Texas
Houston, Texas
Mr P: It says "800 Cranking Amps" not COLD Cranking Amps so maybe it is low... I don't know what the output of my alt is. I think I need to get both of those items checked out.
Pittsburg: I also run a 1 wire setup...Sounds like we have the same issue...
