Page 2 of 3 1 2 3
Re: Cheap but not ugly upsized wheel options for B-body [Re: jon01] #1616008
05/10/14 05:18 PM
05/10/14 05:18 PM
Eugene, Oregon
Secret Chimp Offline OP
Eugene, Oregon
I have a set of 17" Stockton steelies on my wagon, 17x8 with 245/45/17 in front, and 17x10 with 315/35/17 in back.
They will take the same hubcap your wagon currently has on it.
I've been thinking about making a change, if you're interested let me know.
Mine handles fantastic with bigger t-bars and sway bars f/r. 25mph ramps at 45-50, it just hunkers down and goes.
That sounds interesting to me. PM'd you!
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Cheap but not ugly upsized wheel options for B-body [Re: jon01] #1616009
05/16/14 01:52 PM
05/16/14 01:52 PM
Massachusetts
Sneke_Eyez Offline
Sneke_Eyez  Offline
Massachusetts
Count me in on wanting pictures of these on your wagon!
I'm watching this thread closely - the 14s on my 69 Satellite Wagon will be getting changed off sooner than later!
1969 Satellite Wagon - G3 Hemi Swap Incoming. | 1969 Coronet Post Coupe.
2002 Intrepid ES | 2009 Ram SLT | 2004 300M Special | 2002 300M Pro Am - Hers
Are you a New England Mopar Enthusiast?
Come check out the revived NorthEast Mighty Mopar at www.northeastmightymopar.com
Re: Cheap but not ugly upsized wheel options for B-body [Re: jon01] #1616010
05/16/14 03:37 PM
05/16/14 03:37 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Good grief. I shudder to think what those must weigh. 50#+ each or so.
Re: Cheap but not ugly upsized wheel options for B-body [Re: TC@HP2] #1616011
05/17/14 02:02 PM
05/17/14 02:02 PM
GA
roadrunninMark Offline
GA
Someone needs to make 16" or 17" steelie look in aluminum to accept the caps. Make it with the thicker "step" as in the 450 wheels. I think they would look great.
Re: Cheap but not ugly upsized wheel options for B-body [Re: roadrunninMark] #1616012
05/17/14 05:12 PM
05/17/14 05:12 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I think a nostalgic SS look would blend well like some these fro Team III. Cheap they are not, but they are'nt over priced either. Some wheels from Vintage Wheel Works would be cool to.
http://www.team3wheels.com/
http://www.vintagewheelworks.com/
Mopar to the bone!!!
Re: Cheap but not ugly upsized wheel options for B-body [Re: roadrunninMark] #1616013
05/17/14 05:58 PM
05/17/14 05:58 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Someone needs to make 16" or 17" steelie look in aluminum to accept the caps. ...
Someone needs to make 15" to 17" wheels with the steelie look in aluminum. Period.
Re: Cheap but not ugly upsized wheel options for B-body [Re: BigBlockMopar] #1616014
05/17/14 08:51 PM
05/17/14 08:51 PM
Eugene, Oregon
Eugene, Oregon
I'm buying Jon's 17" wheels off of his wagon when he gets his replacements figured out.
Not the lightest I'm sure, but they get me set up for good & relatively cheap tires. Plus I have zero qualms about how they'll look on my car… everything else in my price range I felt kind of iffy about at best.
Re: Cheap but not ugly upsized wheel options for B-body [Re: Secret Chimp] #1616015
05/18/14 12:27 AM
05/18/14 12:27 AM
central Florida
VL21 Offline
VL21  Offline
central Florida
The '66-67 rear wheel well is very restrictive, on a '66 Belvedere 4dr winter beater I had once a factory 15x8 Ramcharger/pickup wouldn't work on the rear, and just as a guess, the wagon openings aren't much different.
The '68-70 well is much bigger.
I am guessing from the look you have the late '80s M body, 15x7 wheels on there now. Dippy cop car wheels are identical but with slots.
Don't know, just sayin' ...
It takes gasoline to interest me.
Re: Cheap but not ugly upsized wheel options for B-body [Re: BigBlockMopar] #1616016
05/18/14 05:09 PM
05/18/14 05:09 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
to add to this I wish they made the aluminum version of D window steel wheels
Re: Cheap but not ugly upsized wheel options for B-body [Re: VL21] #1616017
05/18/14 09:04 PM
05/18/14 09:04 PM
Eugene, Oregon
Eugene, Oregon
Well I'm adding around 3-3.5 inches in rim width and I'm going to use a 275 width tire vs the 215s I have now. I did some really rough measurements and I have around 2 inches between the sidewall and the outer fenderwell and 2.5-3 toward the inner well & spring.
The only solid comparison I could find was Hotchkis' 67 Coronet coupe they put all of their TVS stuff on back in 2009. They used 8 inch wide wheels with 255s in the rear for that one.
I don't know what the BS of these things is (yet), but if the width change is more or less equal inside to outside I'd think I'll be fine.
Re: Cheap but not ugly upsized wheel options for B-body [Re: BigBlockMopar] #1616018
05/19/14 05:51 AM
05/19/14 05:51 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
And NOT screw it up.
I've seen it done right once. Out ov probably a dozen different attempts. I must have seen it in a magazine because if it'd been online i'd have every pic available, but i dont. They were 18's and they looked about as good as possible, thinking a nice 8 outta 10. They actually looked good enough that it looked weird to see such a big steelie . Made the car look smaller. So one way or another, it will never look 100% right with excellent handling, but you shoot for the best you can do.
I have a cunning plan... on how to do it the best way, should i ever trip over a hockey bag full ov hundred dollar bills... until then, its aftermarket.
Re: Cheap but not ugly upsized wheel options for B-body [Re: Pale_Roader] #1616019
05/19/14 11:25 AM
05/19/14 11:25 AM
dangina Offline
dangina  Offline
I here ya, but if I trip over that same bag I'd probably do a custom set of hurricane/vector wheels, the price quote I got was 15 grand for a set of 18's
Re: Cheap but not ugly upsized wheel options for B-body [Re: dangina] #1616020
05/19/14 12:07 PM
05/19/14 12:07 PM
Cooperstown, NY
jrlegacy23 Offline
jrlegacy23  Offline
Cooperstown, NY
Maybe you could set up a group buy and get them for $14,800.... just a thought.
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
Re: Cheap but not ugly upsized wheel options for B-body [Re: jrlegacy23] #1616021
05/19/14 03:27 PM
05/19/14 03:27 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Have them made offshore. Probably will pay more in shipping the container back from China than to have them made.
Re: Cheap but not ugly upsized wheel options for B-body [Re: PHJ426] #1616022
05/20/14 01:13 AM
05/20/14 01:13 AM
5th and plum
redmist Offline
redmist  Offline
5th and plum
These are 17x10 rear, and 17x8 front Coys C-55's
not a bad price, I like the look.
Re: Cheap but not ugly upsized wheel options for B-body [Re: Secret Chimp] #1616023
05/26/14 01:09 PM
05/26/14 01:09 PM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
Well My opinion nothing looks ad cool ad the yo wheeels
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: Cheap but not ugly upsized wheel options for B-body [Re: sublimehemi] #1616024
05/26/14 01:11 PM
05/26/14 01:11 PM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
Here
Re: Cheap but not ugly upsized wheel options for B-body [Re: Secret Chimp] #1616025
05/29/14 05:20 AM
05/29/14 05:20 AM
Eugene, OR
FuryBoy Offline
FuryBoy  Offline
Eugene, OR
I like the Ansen Sprints. I think Year one sells the 17x7s for $165 per wheel.
Re: Cheap but not ugly upsized wheel options for B-body [Re: TC@HP2] #1616026
06/19/14 02:27 PM
06/19/14 02:27 PM
Iowa
jon01 Offline
jon01  Offline
Iowa
Sold the wheels to Charlie, I hope he can get them under his car, it'll look great with them!
Sorry for the late response, here is the only pic I have of it handy.
It will be getting Billet Specialties Dagger G's with M/T 295/45/17 DR's in back so a bit more sidewall.
The rears are heavy but not as heavy as you would think. The 15x10's/37's I had on my Scout were much heavier.
Too heavy? Just add HP and brakes to compensate!
68 Charger R/T - #'s matching car, 499/727/3.91
Re: Cheap but not ugly upsized wheel options for B-body [Re: jon01] #1616027
06/19/14 02:34 PM
06/19/14 02:34 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I cant find them on their site, how much are they?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Page 2 of 3 1 2 3
