Re: Cheap but not ugly upsized wheel options for B-body
[Re: jon01]
#1616008
05/10/14 05:18 PM
05/10/14 05:18 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
I have a set of 17" Stockton steelies on my wagon, 17x8 with 245/45/17 in front, and 17x10 with 315/35/17 in back. They will take the same hubcap your wagon currently has on it. I've been thinking about making a change, if you're interested let me know. Mine handles fantastic with bigger t-bars and sway bars f/r. 25mph ramps at 45-50, it just hunkers down and goes.
That sounds interesting to me. PM'd you!
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: jon01]
#1616009
05/16/14 01:52 PM
05/16/14 01:52 PM
Posts: 321 Massachusetts
Sneke_Eyez
Massachusetts
Count me in on wanting pictures of these on your wagon!
I'm watching this thread closely - the 14s on my 69 Satellite Wagon will be getting changed off sooner than later!
1969 Satellite Wagon - G3 Hemi Swap Incoming. | 1969 Coronet Post Coupe. 2002 Intrepid ES | 2009 Ram SLT | 2004 300M Special | 2002 300M Pro Am - Hers
Are you a New England Mopar Enthusiast? Come check out the revived NorthEast Mighty Mopar at www.northeastmightymopar.com!
[Re: jon01]
#1616010
05/16/14 03:37 PM
05/16/14 03:37 PM
Posts: 5,395 Pikes Peak Country
TC@HP2
Pikes Peak Country
Good grief. I shudder to think what those must weigh. 50#+ each or so.
[Re: roadrunninMark]
#1616013
05/17/14 05:58 PM
05/17/14 05:58 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
Someone needs to make 16" or 17" steelie look in aluminum to accept the caps. ...
Someone needs to make 15" to 17" wheels with the steelie look in aluminum. Period.
[Re: BigBlockMopar]
#1616014
05/17/14 08:51 PM
05/17/14 08:51 PM
Secret Chimp
Eugene, Oregon
I'm buying Jon's 17" wheels off of his wagon when he gets his replacements figured out. Not the lightest I'm sure, but they get me set up for good & relatively cheap tires. Plus I have zero qualms about how they'll look on my car… everything else in my price range I felt kind of iffy about at best.
[Re: Secret Chimp]
#1616015
05/18/14 12:27 AM
05/18/14 12:27 AM
Posts: 1,357 central Florida
VL21
central Florida
The '66-67 rear wheel well is very restrictive, on a '66 Belvedere 4dr winter beater I had once a factory 15x8 Ramcharger/pickup wouldn't work on the rear, and just as a guess, the wagon openings aren't much different. The '68-70 well is much bigger. I am guessing from the look you have the late '80s M body, 15x7 wheels on there now. Dippy cop car wheels are identical but with slots. Don't know, just sayin' ...
It takes gasoline to interest me.
[Re: BigBlockMopar]
#1616016
05/18/14 05:09 PM
05/18/14 05:09 PM
Posts: 1,491 Lethbridge, AB, Canada
dangina
to add to this I wish they made the aluminum version of D window steel wheels
[Re: VL21]
#1616017
05/18/14 09:04 PM
05/18/14 09:04 PM
Secret Chimp
Eugene, Oregon
Well I'm adding around 3-3.5 inches in rim width and I'm going to use a 275 width tire vs the 215s I have now. I did some really rough measurements and I have around 2 inches between the sidewall and the outer fenderwell and 2.5-3 toward the inner well & spring.
The only solid comparison I could find was Hotchkis' 67 Coronet coupe they put all of their TVS stuff on back in 2009. They used 8 inch wide wheels with 255s in the rear for that one.
I don't know what the BS of these things is (yet), but if the width change is more or less equal inside to outside I'd think I'll be fine.
[Re: BigBlockMopar]
#1616018
05/19/14 05:51 AM
05/19/14 05:51 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
And NOT screw it up.
I've seen it done right once. Out ov probably a dozen different attempts. I must have seen it in a magazine because if it'd been online i'd have every pic available, but i dont. They were 18's and they looked about as good as possible, thinking a nice 8 outta 10. They actually looked good enough that it looked weird to see such a big steelie . Made the car look smaller. So one way or another, it will never look 100% right with excellent handling, but you shoot for the best you can do.
I have a cunning plan... on how to do it the best way, should i ever trip over a hockey bag full ov hundred dollar bills... until then, its aftermarket.
[Re: Pale_Roader]
#1616019
05/19/14 11:25 AM
05/19/14 11:25 AM
dangina
I here ya, but if I trip over that same bag I'd probably do a custom set of hurricane/vector wheels, the price quote I got was 15 grand for a set of 18's
[Re: PHJ426]
#1616022
05/20/14 01:13 AM
05/20/14 01:13 AM
Posts: 305 5th and plum
redmist
5th and plum
These are 17x10 rear, and 17x8 front Coys C-55's not a bad price, I like the look.
[Re: Secret Chimp]
#1616023
05/26/14 01:09 PM
05/26/14 01:09 PM
Posts: 373 sandwich IL
sublimehemi
sandwich IL
Well My opinion nothing looks ad cool ad the yo wheeels
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
[Re: jon01]
#1616027
06/19/14 02:34 PM
06/19/14 02:34 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
Sold the wheels to Charlie, I hope he can get them under his car, it'll look great with them!
Sorry for the late response, here is the only pic I have of it handy.
It will be getting Billet Specialties Dagger G's with M/T 295/45/17 DR's in back so a bit more sidewall.
The rears are heavy but not as heavy as you would think. The 15x10's/37's I had on my Scout were much heavier. Too heavy? Just add HP and brakes to compensate!
I cant find them on their site, how much are they?
