Re: Master Cylinder? [Re: Dragula] #1615973
05/09/14 09:44 PM
05/09/14 09:44 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Well....How about reversed lines off the Master Cylinder!!!!!
Bingo!!!!!
what do you mean
Re: Master Cylinder? [Re: Quicktree] #1615974
05/12/14 11:31 PM
05/12/14 11:31 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Well....Scratch the reversed lines... It was a lot more complicated than that...
Turns out $750 later....It was the weird angle the master cylinder was moved to so it would clear the fender well headers.
The brake rod was at such an angle, it wasn't able to fully engage or disengage...I was told I was super lucky I didn't have a real incident.
Re: Master Cylinder? [Re: Dragula] #1615975
05/13/14 01:41 AM
05/13/14 01:41 AM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
Good!! Brakes are really important as We all clearly know. Glad You found the source of Your problem.
Re: Master Cylinder? [Re: Dragula] #1615976
05/13/14 01:43 AM
05/13/14 01:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
So how did you change the angle of the master
Re: Master Cylinder? [Re: MR_P_BODY] #1615977
05/13/14 07:54 AM
05/13/14 07:54 AM
Dragula Offline OP
Dragula  Offline OP
That is where $750 comes in handy, as well as someone who can weld. Maybe I can get a picture.
Re: Master Cylinder? Update! [Re: Dragula] #1615978
05/13/14 03:47 PM
05/13/14 03:47 PM
mogadore ohio 44260
racingblues1426 Offline
mogadore ohio 44260
I had a feeling you'd find that the rod was the culprit. Been there and done it. Hope all else works out and you go kick some x brands butts.
