Re: Wiring confusion. [Re: moparfan53] #1615167
05/06/14 09:37 PM
05/06/14 09:37 PM
Mt.Gilead, Ohio
OhioMopar Offline OP
Mt.Gilead, Ohio
I'm still checking wires and ohms and playing with the test light. But it seems the switch is bad.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Wiring confusion. [Re: OhioMopar] #1615168
05/06/14 10:08 PM
05/06/14 10:08 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Can you swap the wires side for side and see if you have the reverse situation?
I have mechanical Aptitude.
I can screw up anything.
Re: Wiring confusion. [Re: bboogieart] #1615169
05/07/14 05:57 AM
05/07/14 05:57 AM
Oh
His and Her 69's Offline
Oh
Not sure but my RR did the same thing and it was the blinker switch in the column. I changed that out and all my lights work Good now.
I messed with wires, grounds, bulbs, etc till I finally figured it out.
If I turned on the opposite side blinker then the bad side lights would work like normal.
David
Re: Wiring confusion. [Re: His and Her 69's] #1615170
05/07/14 01:13 PM
05/07/14 01:13 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Mine just straight up doesn't work. I pulled the cancelling cam out and jumped things and read things. It looks like the switch. I'll get back to it this weekend, I hope. I have a little over a week to get the little things worked out for Columbus.
1969 Dart GTS 340
2015 Dodge Dart GT
