Re: Made it to the track last weekend... [Re: Triple Threat] #1615044
05/12/14 02:44 PM
05/12/14 02:44 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
very nice!!!!!!!!!!!!!!
Re: Made it to the track last weekend... [Re: sixpackgut] #1615045
05/12/14 03:06 PM
05/12/14 03:06 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Impressive! I see that you have reduced the rear end rotation a bunch from where it was:
https://www.youtube.com/watch?v=t7BVKoamhQs
Re: Made it to the track last weekend... [Re: Airwoofer] #1615046
05/12/14 05:35 PM
05/12/14 05:35 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Yea here it is on the 1.17 from this weekend. Still not quite what I want but making progress.
https://www.youtube.com/watch?v=xy3L7tf3CxU&feature=youtu.be
Re: Made it to the track last weekend... [Re: Forest] #1615047
05/12/14 06:31 PM
05/12/14 06:31 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Looks fairly good there..Heck my hoopty has never been 1.17, but we may be changing that soon
Re: Made it to the track last weekend... [Re: Al_Alguire] #1615048
05/12/14 06:58 PM
05/12/14 06:58 PM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
Al take the throttle stop off!!
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: Made it to the track last weekend... [Re: Forest] #1615049
05/12/14 11:03 PM
05/12/14 11:03 PM
SoCal
Brian Hafliger Offline
SoCal
What? You want more??? Hmmm...I don't remember you saying anything about that! Ha ha!
What are you shifting at? How,s the carb jetted?
But you are happy, yes?
Brian Hafliger
Re: Made it to the track last weekend... [Re: Brian Hafliger] #1615050
05/13/14 12:32 AM
05/13/14 12:32 AM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Ha ha Brian I was talking about the 4 link / shock setup. I am happy with the engine and converter performance.
Timing is at 35*, carb is 96 squared...maybe still lean in good air. Shift made @ 7450 through the traps at the same. 2 step at 5k converter flashes to 6k.
Never messed with air bleeds but thinking that may be the next step now that the carb is up to 96's from 92's?
Anyone know the difference in NGK 7405's that I'm running vs. NGK 4091's? What about heat ranges...I'm running 9's now.
Re: Made it to the track last weekend... [Re: Triple Threat] #1615051
05/13/14 10:28 PM
05/13/14 10:28 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
When are you bringing it to sea level?
Got me we have a busy summer, Plan to go to the Woodburn Mopar Nats, but the DA isn't always great that weekend.
Double header at Pacific May 17th-18th would be a good opportunity.
I just heard the weather forecast it is going to be hot the next few days and then RAIN for the weekend.
I would love to see your car run here.
How often do they run at Renegade? I have never been there.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Made it to the track last weekend... [Re: Forest] #1615052
05/13/14 10:54 PM
05/13/14 10:54 PM
WA
JD Dart Offline
JD Dart  Offline
WA
I run the 4554 Ngk I tried the 7173 which is 8 heat range it's the extended tip with them it looked like it was close to detonation so I went back to the 4554 they always look good and there was to power from the extended tip.
Re: Made it to the track last weekend... [Re: Polarapete] #1615053
05/13/14 11:59 PM
05/13/14 11:59 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Usually every other weekend. You should come the 24th-25th of this month for a double header feature race. They pay $500 to win Super Pro. We had 28 cars last weeknd and they said if there is 32 or more they'll bump it up $750.
Re: Made it to the track last weekend... [Re: Forest] #1615054
05/16/14 11:36 PM
05/16/14 11:36 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I would love to be there for that, but, as usual life interferes with fun I have to finish putting my '87 back together and wiring it to pull the cargo trailer. I have set myself a goal that the truck and trailer will be running and picking up everything in the club storage unit on May 31st for the car show on June 1st. Oh and BTW, I am looking at a (new to me) house 51 miles south of us on Saturday the 17th and our existing house goes on the market June 1st, too. I will probably be a little too busy to play at anything in June
But you go ahead without me
2008 Honda Element
