Page 7 of 48 1 2 5 6 7 8 9 47 48
Re: Modern Bullitt build [Re: Keepat] #1815075
04/30/15 01:08 AM
04/30/15 01:08 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Only the trunk floor is reproduction, all the parts under the seat are original to this car. I would be surprised if the parts that you are looking for or not available. Good luck!
Pat
Re: Modern Bullitt build [Re: Keepat] #1815165
04/30/15 03:43 AM
04/30/15 03:43 AM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
Wow, that's some nice work there. I don't think it will ever rust now.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: Modern Bullitt build [Re: gregsrt] #1815855
04/30/15 10:17 PM
04/30/15 10:17 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I just remembered today marks one year into this build that I’m shooting to finish by next spring. It is so true how fast time fly’s by as we get older :-(
Pat
Re: Modern Bullitt build [Re: Keepat] #1816252
05/01/15 12:28 PM
05/01/15 12:28 PM
Maryland
rhamson Offline
rhamson  Offline
Maryland
Still on the rotisserie waiting to get some money for suspension parts to put her back on her wheels and start the body work. Thanks for asking.
Re: Modern Bullitt build [Re: Keepat] #1818317
05/04/15 10:53 AM
05/04/15 10:53 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I drop the K member and remove the bump stops from the frame rails. The K member has SSBC disc brakes and is in good shape with a tight steering box and I would like to sell it if anyone is interested? I will post it for sale soon.
Pat
Re: Modern Bullitt build [Re: Keepat] #1818469
05/04/15 02:04 PM
05/04/15 02:04 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I cut the bump stops off so that they could be reused on another car if someone needs a set?
Cleaned up the frame rails and fit the RMS K member.
Pat
Re: Modern Bullitt build [Re: Keepat] #1818973
05/04/15 11:46 PM
05/04/15 11:46 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Even with all my calculations, double checking with the different venders, and other threads with similar suspensions it was a relief seeing the front wheel on the car with great clearance and no rubbing issues with in the fender.
Pat
Re: Modern Bullitt build [Re: Keepat] #1822196
05/08/15 10:06 PM
05/08/15 10:06 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I mocked up the steering U-joints and cut the shaft to fit, nice hardware supplied by RMS!
Pat
Re: Modern Bullitt build [Re: Keepat] #1826362
05/14/15 01:05 AM
05/14/15 01:05 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I started relief cutting the right side only of the trans tunnel to fit the T-56 transmission. I saw this method used on an E body in another forum and it looked like a clever way of disguising the modification of the trans tunnel to fit the big 6 speed.
Pat
I attached a guide so I could make a straight cut with the plasma cutter.
Re: Modern Bullitt build [Re: Keepat] #1826496
05/14/15 11:34 AM
05/14/15 11:34 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Nice work, I really like how you used the guide for making a clean cut. Can't wait to see your car finished!
Re: Modern Bullitt build [Re: Keepat] #1828068
05/16/15 09:56 PM
05/16/15 09:56 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Fabricated an aluminum K member dolly as I will be installing and removing the motor and trans a lot over the next few week to fit the tunnel to the transmission.
I will have a scissor jack at the trans end to help adjust the fit in the car.
With K member dolly made I move the motor from the house to the Hot Rod shop. This is as close as the motor has gotten to the charger and it is about to get closer!
Pat
Re: Modern Bullitt build [Re: Keepat] #1829085
05/18/15 12:33 PM
05/18/15 12:33 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Got to love a Plasma cutter! Used about 7 layers of tape for a guide and cut!
Pat
[img]http://i949.photobucket.com/albums/ad340/kurts68fastback/th_IMG_3182_zpslqfcsvbc.mp4[/img]
Click on pic for video.
Re: Modern Bullitt build [Re: Keepat] #1831130
05/20/15 10:29 PM
05/20/15 10:29 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Nice work!
Re: Modern Bullitt build [Re: Keepat] #1833018
05/23/15 11:39 PM
05/23/15 11:39 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Installed the bell housing and transmission to the motor and set it up on the K member dolly. I think I will need to remove the right side valve cover to clear the right side inter fender. Tomorrow I will test fit the motor and trans in the car to check for tunnel clearances.
Pat
Re: Modern Bullitt build [Re: Keepat] #1833045
05/24/15 12:22 AM
05/24/15 12:22 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Dayum, that is coming out really nice...
Re: Modern Bullitt build [Re: Keepat] #1833169
05/24/15 11:55 AM
05/24/15 11:55 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Just like my 1st Charger with the Ray Barton Gen 2 Hemi I needed to remove the right side valve cover to make it past the inter fender. I’m sure if the motor had stock valve covers it would have fit but the Indy valve covers are taller. Now I can start shaping the tunnel to fit the trans. With the lift and the fact that you can put the motor in from the bottom makes fitting and working on the tunnel a lot easier!
I’m left with about 2 3/8” hood clearances, tight but it should work with a custom made air cleaner.
Pat
Re: Modern Bullitt build [Re: Keepat] #1835314
05/27/15 03:14 PM
05/27/15 03:14 PM
Maryland
rhamson Offline
rhamson  Offline
Maryland
You do great work Pat! Keep it up.
Re: Modern Bullitt build [Re: rhamson] #1836082
05/28/15 04:56 PM
05/28/15 04:56 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thanks Ralph!
Re: Modern Bullitt build [Re: Keepat] #1836083
05/28/15 04:57 PM
05/28/15 04:57 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I have the trans tunnel tack-welded in place and ready to double check the trans fit.
I open the tunnel about 3” at the front and about 1 1/4” at the tail shaft. Now I need to make an removable shifter cover that will use the original shifter boot.
Pat
Re: Modern Bullitt build [Re: Keepat] #1836521
05/29/15 10:44 AM
05/29/15 10:44 AM
Maryland
rhamson Offline
rhamson  Offline
Maryland
Pat
How are you keeping track of the drive shaft geometry? Since this transmission goes in much higher than stock, will it affect the pinion angle at the differential? Or are you going to equal the two out after you get the transmission set?
