Page 19 of 48 1 2 17 18 19 20 21 47 48
Re: Modern Bullitt build [Re: Keepat] #2192436
11/08/16 10:09 PM
11/08/16 10:09 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Indy used pictures and specs of my motor in their on line add for the 6.1 :-)
click on the link and scroll to the bottom.
Pat
http://www.indyheads.com/6.1hemiengines.html
Re: Modern Bullitt build [Re: Keepat] #2207661
12/04/16 05:00 PM
12/04/16 05:00 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Just starting to get back to work on the charger as I've been very busy at work. I did put some time in on the steering wheel project and I'm happy with my progress so far. I found another steering wheel with good chrome on the spokes. And I decided to leave small 1" sections of the original plastic wood grain in place to help position the outer ring as well as locate the inner ring that I made smaller in diameter. My plan was to use a product called West System which is a two-part epoxy that has a variety of fillers to help color, thicken, and add strength. I started by making a small mold of the shape I was looking for and just move it around using plumbers putty too damn up the ends when I filled it with a epoxy. This worked OK but didn't give me the results I was looking for so I decided to make a full mold. After using it to make the top half of the steering wheel I modified it to clear the spokes and used it again for the bottom half of the steering wheel. This worked great and other than a few air pockets which I can fill-in along with the holes that I drilled so I could use a syringe to inject epoxy into the bottom of the mold I think it turned out great. I plan on making it a darker shade of brown and then comes the tedious part of replicating the wood grain.
Pat
This is a picture of the partial mold that I started using
Here's the mold has been waxed and filled with epoxy
First pull of the new mold
Then I cut the mold to clear the spokes and flip the steering wheel to redo the shape on the backside of the steering wheel.
[img]http://i949.photobucket.com/albums/ad340/kurts68fastback/image_zps5dorh8i1.jpeg[/img]
Re: Modern Bullitt build [Re: Keepat] #2211142
12/10/16 11:53 AM
12/10/16 11:53 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Wow that steering wheel looks great!
Re: Modern Bullitt build [Re: Keepat] #2211727
12/11/16 10:39 AM
12/11/16 10:39 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
It's getting there, we'll see how good it looks after I'm done with fake wood grain.
Thank you
Pat
Re: Modern Bullitt build [Re: Keepat] #2214278
12/15/16 07:05 AM
12/15/16 07:05 AM
Dalarna
coronet69 Offline
coronet69  Offline
Dalarna
wow i have read from 1 to 19 at a stretch yesterday
really good work!
what tool do you use to cut the metal, to cut a small pcs from a frame
Re: Modern Bullitt build [Re: coronet69] #2215154
12/16/16 04:52 PM
12/16/16 04:52 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
really good work!
19 pages in 1 day, you must have been bored ;-)
For cutting metal a Plasma cutter works great with a guide and I also use a small Dremmel tool.
Thank you & welcome to the site!
Pat
Re: Modern Bullitt build [Re: Keepat] #2215627
12/17/16 01:53 PM
12/17/16 01:53 PM
Dalarna
coronet69 Offline
coronet69  Offline
Dalarna
Home with the flu frown
Have some holes I have to fix on my coronet, maybe i have to buy a plasma cutter... there are cheap ones at aliexpress for about $200, But Im not sure if it will work?
Re: Modern Bullitt build [Re: Keepat] #2218739
12/22/16 01:11 AM
12/22/16 01:11 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
40+ hours and the steering wheel is just about finished. With a lot of sanding and adding more epoxy I got the oval shape I was looking for. Then I used a hook blade to add the wood grain affect. For color I used wood stain to darken the wood grain cuts and to get the color I was looking for.
Pat
This is the difference in size and shape from the original steering wheel grip to the new larger oval.
Re: Modern Bullitt build [Re: Keepat] #2218849
12/22/16 10:23 AM
12/22/16 10:23 AM
mopar4don Offline
mopar4don  Offline
Beautiful job Pat!
Re: Modern Bullitt build [Re: Keepat] #2218954
12/22/16 01:41 PM
12/22/16 01:41 PM
Newton, KS
70B5Cuda Offline
70B5Cuda  Offline
Newton, KS
Ridiculously cool work...
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: Modern Bullitt build [Re: mopar4don] #2219064
12/22/16 03:53 PM
12/22/16 03:53 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted By mopar4don
Beautiful job Pat!
Thanks Don and Merry Christmas to you and yours!
Pat
Re: Modern Bullitt build [Re: 70B5Cuda] #2219065
12/22/16 03:53 PM
12/22/16 03:53 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank you sir!
Pat
Re: Modern Bullitt build [Re: Keepat] #2219369
12/23/16 12:33 AM
12/23/16 12:33 AM
Colorado
MoparCar Offline
MoparCar  Offline
Colorado
What an awesome build and talent you have!!!
Thanks for sharing!
Wes
Re: Modern Bullitt build [Re: Keepat] #2219698
12/23/16 04:34 PM
12/23/16 04:34 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Wow, just wow!! To say your level of detail is amazing would be an understatement! That wheel is over the top and something that I can say I have never really seen most restorers tackle themselves. I can't wait to see updates on this build. You have a talent that few builders do, keep up the beautiful work!
Re: Modern Bullitt build [Re: NV69B7RR] #2219932
12/24/16 12:14 AM
12/24/16 12:14 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I'm not to sure about talent, more like rocks in my head ;-)
Thank you!
Pat
Re: Modern Bullitt build [Re: Keepat] #2224471
01/01/17 01:51 AM
01/01/17 01:51 AM
Superfreak
Superfreak
Nicely done!
Re: Modern Bullitt build [Re: Keepat] #2230702
01/09/17 11:53 AM
01/09/17 11:53 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Reassemble my home made paint booth over the weekend. I used boat shrink wrap for the walls and ceilings.
These two walls can roll up to get the car in and out.
Four 20x20x4 intake filters.
Window box holds two 20x20 fans and track for quick change 20x25x1 discharge filters.
A little clean up and the paint booth will be ready. This will be the 3rd car to be painted in this home made booth.
Pat
Re: Modern Bullitt build [Re: Keepat] #2230816
01/09/17 02:47 PM
01/09/17 02:47 PM
Colorado
MoparCar Offline
MoparCar  Offline
Colorado
Great build and booth! What are you using for a fan and is it a positive or negative pressure booth?
Thanks Wes
Re: Modern Bullitt build [Re: MoparCar] #2231033
01/09/17 07:56 PM
01/09/17 07:56 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thanks Wes
Wes,
I'm using two 20 x 20" fans pulling the air out of the booth, with air in to the booth from the four large intake filters.
Pat
Re: Modern Bullitt build [Re: Keepat] #2231098
01/09/17 09:21 PM
01/09/17 09:21 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Pat - nice booth! I will have to steal some of this. Weather in the Washington DC area not real good now. What if anything you doing for heat?
