Page 5 of 6 1 2 3 4 5 6
Re: Borgeson / Pitman Fitment Issue [Re: cogen80] #1613759
12/08/14 02:59 PM
12/08/14 02:59 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
I have now ordered and paid up for a replacement steering box. 750 dollars plus shipping. Will post outcome once installed.
any updates on this?
I did install the replacement box, but alignment issues remained with no change.
I then built a an 1/8th inch shim out of steel stock and inserted it between the steering box and K member on the 2 hole mounting side of the box. This is discussed in detail on another thread that I had initiated on this topic. If anyone is interested I will post a link to that one.
All is perfectly well now,,except minor issue of 1/2 inch difference in tie rod lengths left to right side. Adding a very slight thickness to this shim will likely address this.
Returned one box to Borgeson asking for refund of charge for the box plus shipping charges each way(close to 100 dollars).
They returned the 750 dollars for the steering box charge,,,,but not the shipping charges. Not dealing with Nordstrums, Costco or Summit here,,,I call it a day and moved on. Box and car now performing to initial expectation,,,albeit some 9 months and a few hundred dollars beyond what was anticipated.
Re: Borgeson / Pitman Fitment Issue [Re: Sxrxrnr] #1613760
12/09/14 07:35 AM
12/09/14 07:35 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
do you have before and after pics of the box shimmed?
Re: Borgeson / Pitman Fitment Issue [Re: dangina] #1613761
12/09/14 12:38 PM
12/09/14 12:38 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Do you have a bottom shot in wide angle to see all the linkage from end to end?
A shot of the coupler from the top, close up?
Re: Borgeson / Pitman Fitment Issue [Re: BergmanAutoCraft] #1613762
12/09/14 12:51 PM
12/09/14 12:51 PM
Santa Fe Springs, CA
Dan@Hotchkis Offline OP
Are the latest style boxes going to be all new castings/forgings or rebuilt units as well? Anything that saves space is a win. Hopefully Borgeson can get these issues sorted out.
Re: Borgeson / Pitman Fitment Issue [Re: Dan@Hotchkis] #1613763
12/09/14 02:07 PM
12/09/14 02:07 PM
Long Island, NY USA
Long Island, NY USA
The new boxes are all new and smaller. However, due to the new box being slightly narrower between the pitman and input shafts, there will be some angle built in. The factory coupler will be able to take up the angle without issue.
Re: Borgeson / Pitman Fitment Issue [Re: BergmanAutoCraft] #1613764
12/09/14 02:19 PM
12/09/14 02:19 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The factory coupler isn't really there for that. It's there to account for chassis flex in the system not poor engineering.
Don't be the exception.
Re: Borgeson / Pitman Fitment Issue [Re: BergmanAutoCraft] #1613765
12/09/14 02:46 PM
12/09/14 02:46 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
After shimming, shaft goes straight in. This photo is before box is shimmed showing angle as shaft enters coupler.
Have not taken photo of entire drag link and tie rods. Can do so and will post when done. Will also post top view photo of coupler/shaft as is post shimming.
Re: Borgeson / Pitman Fitment Issue [Re: Sxrxrnr] #1613766
12/09/14 04:13 PM
12/09/14 04:13 PM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
What headers are those? There is no way my Doug's will fit with the steering angle crowding them...
Re: Borgeson / Pitman Fitment Issue [Re: Tomswheels] #1613767
12/09/14 07:36 PM
12/09/14 07:36 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
TTI 2 inch tubes.
Now have more clearance than had with stock(Firm Feel modified) PS steering box. With stock box, header tube actually rested against box,,,had to shove engine slightly toward passenger side to gain 1/4 inch clearance. This box(Borgeson) gives more clearance than did Mopar box.
But with Borgeson I believe that steering shaft itself was a bit tighter to the Borgeson, until I shimmed it to correct its positioning on K member.
Re: Borgeson / Pitman Fitment Issue [Re: Supercuda] #1613768
12/10/14 10:53 AM
12/10/14 10:53 AM
Long Island, NY USA
Long Island, NY USA
I wouldn't call is "poor engineering".
If what you are saying is true, the shaft would not have any ability to rotate in the coupler, it would be a solid sliding part. I agree the factory installations all appear straight, but I bet they are not if they were measured accurately.
The fact of the matter is the new box is narrower between the shafts center to center than the OE box.
The way I see it you have a couple choices. Stay in the dark ages being the only make with 60 year old steering, use the new box and get over that visual part of the angle that doesn't present any operational malfunction or design, market and engineering something better.
I'm all ears!
Re: Borgeson / Pitman Fitment Issue [Re: BergmanAutoCraft] #1613769
12/10/14 11:30 AM
12/10/14 11:30 AM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
I'm all ears!
And what do you reccommend I do with $500 worth of headers that no longer fit?
Re: Borgeson / Pitman Fitment Issue [Re: BergmanAutoCraft] #1613770
12/10/14 11:34 AM
12/10/14 11:34 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I'm all ears!
1. the shaft doesn't rotate in the stock coupler, it slides and it only slides.
[image]http://www.forabodiesonly.com/mopar/attachment.php?attachmentid=1714585377&stc=1&d=1358819324[/image]
2. The Delphi box is still recirculating ball, just like my "60 year old" design box. It is just calibrated different. If it were "modern" it'd be rack and pinion.
3. The Delphi box's ratio is 14:1, OEM is 14.7:1, not real difference.
4. The Delphi box is smaller and lighter.
5. For half the price I can get FF to rebuild my box, recalibrate the feel and have it fit properly.
6. if I wanted the most room I'd run R&P.
Re: Borgeson / Pitman Fitment Issue [Re: Supercuda] #1613771
12/10/14 12:05 PM
12/10/14 12:05 PM
Long Island, NY USA
Long Island, NY USA
If you've ever worked with the coupler, it CAN rotate in all directions. The factory ratio is 16:1 btw. The valving on the Delphi box is light years ahead of the oe box. Don't knock it until you've tried it, and get your facts straight before spouting off from behind your keyboard.
If I've said it once, I've said it a thousand times. I'm very easy to get a hold of for intelligent conversation. For some reason, when it comes to this board people loose their manners.
Re: Borgeson / Pitman Fitment Issue [Re: BergmanAutoCraft] #1613772
12/10/14 05:47 PM
12/10/14 05:47 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I thought the factory ratio was 15.7 ?
I agree that there are some real [Edited by Moparts - Family Friendly Site - Keep it clean] members here. They'd complain about being hung with a new rope. THEY often excuse their complaints by saying that the parts will never improve if we just accept inferior designs. This is true to some extent but you can find fault in almost any design if you are "that" type of person.
This steering box may be great but the cost keeps me out of it.
The 4 speed auto from the company that bought out Kiesler sounds great too. again, $5000-$6500 is far out of reach.
I'll never buy any one of those coli over front end sets for my classics, but that is because I disagree with their design.
Re: Borgeson / Pitman Fitment Issue [Re: Kern Dog] #1613773
12/10/14 09:25 PM
12/10/14 09:25 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
It has already been determined that the steering box needs to be shimmed in order to align its centerline with the centerline of the steering column. If the ctr line is skewed it's geometric effect is seen in the ctr to ctr distance betw the right and left side tire rods.
It is incorrect to install this steering box without aligning the box to the steering culoumn and maybe then the tie rods will set up properly side to side. It is bad advice to tell some one it's ok to install the box crooked and there is no need to shim for proper alignment and that its perfectly ok for the coupling to be misaligned with the box. Wow. Then there are the smart people figuring out what the problems are and the solution gets ignored.
So where is the shim plate to properly support the product? The box needs a solid platform to mount to.
Re: Borgeson / Pitman Fitment Issue [Re: ThermoQuad] #1613774
12/10/14 10:05 PM
12/10/14 10:05 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Take a look at my posted photos that was taken from underneath the steering box. You can see the shim that I made out of 1 inch wide by 1/8th inch steel stock.
In the photo you can see the shiny steel shim between the black paint of the K member and the steering box.
The post photo is several postings above this one,,,also read the associated text. You can also use Williams washers as Hotchkis had recommended.
If you do not shim you will have toe alignment issues, box will not be on top crnter and shaft will be at an angle into coupler,,,which is the least concern. The angle just illustrates that you likely have a problem.
I post the photo again.
Re: Borgeson / Pitman Fitment Issue [Re: Sxrxrnr] #1613775
12/10/14 11:09 PM
12/10/14 11:09 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Borgeson / Pitman Fitment Issue [Re: astjp2] #1613776
12/11/14 12:58 AM
12/11/14 12:58 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Why cant they just weld the fuggin ears on right? They have perfected welding them on 12 degrees frickin off! Do they live in a cave with a company wide ban on photographs?
Mopar to the bone!!!
Re: Borgeson / Pitman Fitment Issue [Re: 72Swinger] #2037529
03/23/16 11:01 PM
03/23/16 11:01 PM
5th and plum
redmist Offline
redmist  Offline
5th and plum
Bump to the top!!!
Add me to the list of folks who can't get the box centered. This is one of the new "Smaller" boxes.
I have it installed on a QA1 K. I had to add a washer on the outboard mounting bolt to get the box to even be close to engaging the coupler from Bergman.
Now it's all in, and it has a nasty angle from the steering shaft to the box. Not a big deal...
However!
I also now have the tie rods that can't be adjusted into spec. The passenger side is bottomed out of adjustment and can't get to spec. The wheel is still toed in. The drivers side is adjusted way out, and can get to spec, but the length difference between each tie rod is almost 2"!!
To correct this issue, I would need to shim the double bolt side of the box. This would put the input as such an extreme angle that the Bergman coupler would have to have the dust shield/gasket removed to even engage the splines in the box.
I am thinking my only option is to remove the pitman, grind out the four master splines, and install the pitman one spline out of phase.
It is a dang small box though!
Re: Borgeson / Pitman Fitment Issue [Re: redmist] #2037582
03/24/16 12:21 AM
03/24/16 12:21 AM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
I have to agree with you Tom I have driven with the Firm feel boxes and I am not impressed. The set up in the Valiant with the new box and the cooler is great and there is plenty of space around the box.
