Page 2 of 13 1 2 3 4 12 13
Re: "Custom 33" [Re: Matt Erich] #1613491
06/28/14 01:10 PM
06/28/14 01:10 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
4 link mocked up on my chassis.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1613492
07/10/14 09:50 PM
07/10/14 09:50 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Old school tires and wheels going on my 33.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1613493
09/02/14 04:35 AM
09/02/14 04:35 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
X-mas came early this year.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1613494
09/02/14 04:38 AM
09/02/14 04:38 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
pic2
Fastest 300
Re: "Custom 33" [Re: Crizila] #1613495
09/02/14 04:40 AM
09/02/14 04:40 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
pic3
Fastest 300
Re: "Custom 33" [Re: Crizila] #1613496
09/02/14 03:04 PM
09/02/14 03:04 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Man, that is sweet looking!
Re: "Custom 33" [Re: Crizila] #1613497
09/02/14 11:51 PM
09/02/14 11:51 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Looks like fun, wiring a fiberglass car has its challenges DAMHIK.
Re: "Custom 33" [Re: moparpollack] #1613498
09/03/14 08:52 PM
09/03/14 08:52 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Ya, can you say - lots of grounds .
Fastest 300
Re: "Custom 33" [Re: Crizila] #1613499
09/03/14 09:21 PM
09/03/14 09:21 PM
moparx Offline
moparx  Offline
bus bars come in handy.
Re: "Custom 33" [Re: moparx] #1613500
09/03/14 09:41 PM
09/03/14 09:41 PM
my own world
theraif Offline
theraif  Offline
my own world
I need to start playing mega millions that would be an awesome race car
Re: "Custom 33" [Re: theraif] #1613501
09/03/14 10:15 PM
09/03/14 10:15 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Should run mid /hi 12's with a warmed up 360 / 727 and 3.55 gears.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1613502
09/09/14 06:21 PM
09/09/14 06:21 PM
IN
Matt Erich Offline
Matt Erich  Offline
IN
Thanks for the pictures John! Its always fun watching customer builds in the process and from looking at your previous builds I am sure the 33 is going to turn out great!
The ground problem will likely be very minimal as we have full 1/4 thick steel floors and interior caging that bolts directly to the frame. This should make finding a solid ground easy and quick.
Good luck on the build and like I have always said call anytime!!!!!!!
Matt
Owner of Custom33.com 1933 Plymouth Coupe and Roadster Kits
Re: "Custom 33" [Re: Matt Erich] #1613503
09/09/14 08:49 PM
09/09/14 08:49 PM
dogdays Offline
dogdays  Offline
1/4" thick steel floors? Why? Are you a retired Ford engineer who truly believes that "road-hugging weight" advertisement?
Just checking...
R.
Re: "Custom 33" [Re: dogdays] #1613504
09/09/14 09:25 PM
09/09/14 09:25 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
" Are you a retired Ford engineer". - BIT YOUR TONGUE!!! 1/4" floor plates bolt through the body, body bushings, and in to the frame rails with 12 1/2"-20 bolts to stiffen up the center of the chassis. I want both front tires to get "equal air" when I push on that red NO2 button.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1613505
09/09/14 09:58 PM
09/09/14 09:58 PM
moparx Offline
moparx  Offline
just wondering out loud here. what thickness is the chassis rails ? and with all that plate in the floor, how heavy will it end up being ? with that mass, it should be a good riding car with the correct spring package. incidentally, what rate springs does it use ?
Re: "Custom 33" [Re: moparx] #1613506
09/10/14 02:34 PM
09/10/14 02:34 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Chassis rails = 1/4" wall 2X4. Weight = guess 21-2300 lbs. Car will be fully equipped as a driver - heat, A/C, full exhaust, undercoated, etc. Spring rates; Carrera QA1 adjustable coil overs on all corners. frt. 200 / rr. 125.
Fastest 300
Re: "Custom 33" [Re: moparx] #1613507
09/11/14 12:46 AM
09/11/14 12:46 AM
IN
Matt Erich Offline
Matt Erich  Offline
IN
When I started designing this car and looking at what target market I wanted to focus on I made my mind up that it would be a driver. I am not saying the body and chassis combo cant be a trailer queen!
I built the car for the road and took safety into consideration in every part of the car. Could I of went with thin wall round tubing, 1/2 inch cross member instead of 3/4, 1/2 heims and rodends instead of 3/4, fiberglass floor with a thin piece of wood sandwiched between the glass instead of 1/4 steel???? Sure I could of and it would of saved me THOUSANDS of dollars and I probably would of sold the same number of cars I have to date. BUT I wanted to design a unique street rod for an untapped mopar market that if a husband and wife wanted to jump in and drive across the country they wouldn't be worried about a deer jumping out and going completely threw the car!
The car is fiberglass not steel I understand that so I have made up for the weakness in panels by supporting the structure around it. I am sure John will post pictures of the steel interior and the chassis bracing. I hope to be updating the website soon with new pictures of the latest designs.
Cheers,
Matt
Custom33
Re: "Custom 33" [Re: Matt Erich] #1613508
09/11/14 07:50 PM
09/11/14 07:50 PM
dogdays Offline
dogdays  Offline
Well, putting unnecessary weight in it with really thick steel sections is a lot different than using heavy duty suspension components. The problem for me is that I look at a 1/4" plate just sitting there and know that most of it isn't doing anything.
Metal that's close to or on the neutral axis is just along for the ride.
You don't have to be Anthony Colin Bruce Chapman, but economy doesn't have to mean cheap.
R.
Re: "Custom 33" [Re: dogdays] #1613509
09/11/14 11:13 PM
09/11/14 11:13 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
R.
Actually, if the glass body has a steel structure, and the 1/4" plate is tied into that structure, having 1/4" plate at body to frame mounting points will make a tough glass body.
For many body/frame chassis vehicles, the body and frame often separate in crashes. Usually the bolts pull through the frame mount or through the body structure. With a 1/4" 2" x 4" tube frame, and a 1/4" plate sandwiched between the glass, the body/frame would probably stay together, which is usually helpful for the passengers.
Sounds like he put some thought concerning occupant safety into building the car, which is more then a lot of companies have done over the years. And I don't have a dog in this fight. Gene
Re: "Custom 33" [Re: dogdays] #1613510
09/12/14 12:30 AM
09/12/14 12:30 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
R.
If you have to put weight ( about 80 lbs ) in for safety, the neutral axis zone is where you want to put it - especially if your ass is also sitting in the neutral axis zone. Perfect for mounting seats / seat belts or possibly a roll bar.
Fastest 300
