Re: Bog at full throttle **UPDATED** [Re: ajcasini] #1611278
04/28/14 01:11 AM
04/28/14 01:11 AM
New Braunfels, TX
416challenger Offline OP
New Braunfels, TX
The ifrs are located towards the top of the metering blocks. The idle screws are about a turn and a half out. The transition slot is set about .020, looks like a square. The carb has the idle ease function similar to the Demon carbs. Your turn a screw underneath where the carb air cleaner stud is installed.
Re: Bog at full throttle **UPDATED** [Re: 416challenger] #1611279
04/28/14 08:27 AM
04/28/14 08:27 AM
PA
ajcasini Offline
ajcasini  Offline
PA
Okay do you have the idle ease screw turned at all? If so crank that baby closed. That can be causing us issues. We don't need that to make the car idle.
If open close that down tight and we can tube from there.
Re: Bog at full throttle **UPDATED** [Re: ajcasini] #1611280
04/28/14 02:52 PM
04/28/14 02:52 PM
New Braunfels, TX
New Braunfels, TX
The idle ease screw is currently opened. I will close it and make the idle adjustment with the secondaries.
