68 Charger grill into a 69 #1609337
04/19/14 11:41 AM
04/19/14 11:41 AM
Az
69hemibeep Offline OP
Az
Please don't ask me what I'm up to But are there any differences? Will it bolt in?
1969 Hemi Roadrunner 2nd owner
Re: 68 Charger grill into a 69 [Re: 69hemibeep] #1609338
04/19/14 11:47 AM
04/19/14 11:47 AM
Bowling Green, KY
K
KY Charger Offline
KY Charger  Offline
K
Bowling Green, KY
Im pretty sure it will. If I was at home I'd look at my 68 and tell you where the bolt holes are. I've never liked the 69 grill.
Re: 68 Charger grill into a 69 [Re: 69hemibeep] #1609339
04/19/14 12:53 PM
04/19/14 12:53 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Re: 68 Charger grill into a 69 [Re: moparfan53] #1609340
04/19/14 01:46 PM
04/19/14 01:46 PM
Az
Az
Re: 68 Charger grill into a 69 [Re: 69hemibeep] #1609341
04/20/14 01:21 AM
04/20/14 01:21 AM
Marion, Ohio USA
kab69440 Offline
kab69440  Offline
Marion, Ohio USA
Yes it will. I had a 68 grille in my car for years. You'll need the 68 support as well since the hood release is different and in a different location.
Just because you're paranoid, it doesn't mean they are not out to get you. WANT TO BUY- Looking for a CD by 'The Sub-Mersians' entitled "Raw Love Songs From my Garage To Your Bedroom". Also, any of the various surf-revival compilation albums this band has contributed to.
Re: 68 Charger grill into a 69 [Re: kab69440] #1609342
04/20/14 12:43 PM
04/20/14 12:43 PM
Oakley CA
69charger440_6pa Offline
Oakley CA
Actually the support is the same. You just need the 68 latch and release assembly.
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: 68 Charger grill into a 69 [Re: 69charger440_6pa] #1609343
04/20/14 12:56 PM
04/20/14 12:56 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Yep, the metal carrier frame is about the only piece that is the same between the 2 besides some of the headlamp pivot hardware and linkages
Re: 68 Charger grill into a 69 [Re: gtx6970] #1609344
04/20/14 04:50 PM
04/20/14 04:50 PM
Az
Az
OK, now where would one find a grill This is my daughters car and her idea.
