Re: Ditching the Points
[Re: Copper Dart]
#1608646
04/18/14 05:29 PM
04/18/14 05:29 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Mancini sells an Electronic Ignition kit to convert my '67 383. Have 2 listed, one is a Prestolite, What is the difference? Mopar Performance or Presto? Street/Stock Cruiser not a Race Car. Also I need the steel fuel line from the Stock fuel pump/fuel filter to the #1407 Eddy carb, anyone know the part number? The carb inlet is on the right side rearward corner. I have a rubber fuel line running from the filter to the carb and I dont like it. Help if you can, Thanks
The Mopar Performance kit drops rite in, keeps things stock.. On E-Bay is a brand new Mopar Electronic kit for a 383, but note it is the earlier version which is significantly better than the later ones.. This one has: 1. Distributor has Mallory internals which has adjustable advance settings 2. Orange ECU box is USA made not the Chinese junker
http://www.ebay.com/itm/Mopar-Electronic...948&vxp=mtr
Just my $0.05...
[Re: Sinitro]
#1608647
04/18/14 05:45 PM
04/18/14 05:45 PM
Posts: 3,010 Sac, CA
mopowers
Sac, CA
Just my $0.05...
Nice sales pitch
[Re: mopowers]
#1608648
04/24/14 12:50 AM
04/24/14 12:50 AM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
Package arrived from Mancini this afternoon. I guess I'll take the wife out to dinner.........in the Satellite of course just as soon as I install the electronic ignition conversion kit. Thanks honey! I know theres only two wires to connect but an instruction sheet would have been nice Anyone know of the "correct" way to wire the kit? It did come with a new ballast resistor too.
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: Copper Dart]
#1608649
04/24/14 01:13 AM
04/24/14 01:13 AM
RapidRobert
I believe you run the 2 Pertronix wires to the respective coil primary (+) and (-) terminals and you use the ballast with your OE coil and dont use the ballast if going with a Pertronix coil either a (I) (II) or (III) Pertronix coil to match the respective (I) (II) (III) Pertronix kit that you have. Wired that way if using a ballast the voltage to the Pertronix would be reduced & not sure if that is a problem or not & if so it instead requires the P hot wire be run to switched 12V to bypass a ballast if a ballast is used. What are the ohms of your current coil/ballast and what is the ohms of the P ballast. I would call P & give them your coil ohms & see if they want you to use their ballast. EDIT found my ignitor I kit for a toyouta that I bought at a swap meet for $2. I see that with a ballast that you do run full 12V to the P
[Re: RapidRobert]
#1608650
04/24/14 01:28 AM
04/24/14 01:28 AM
Copper Dart
Robert, my wife purchased the Mopar kit from Mancini as a surprise ( sort of) birthday gift. I need to know the Mopar Performance kit wiring diagram, instructions didn't come with the kit. I know you probably have installed them before. Thanks, pros and cons of mounting ideas welcome too. I may have the diagram in one of my old Chilton manuals in the garage, I'll try to find it the weekend.
[Re: Copper Dart]
#1608651
04/24/14 01:37 AM
04/24/14 01:37 AM
RapidRobert
Is the diagram on the far right in the pic gonna ans your Q's. If not holler back
