Re: Trans Am E-body roll cage pics?
[Re: TC@HP2]
#1606564
04/13/14 11:00 PM
04/13/14 11:00 PM
Posts: 27,465 So Cal
autoxcuda
So Cal
Unless you're going for a spot on reproduction of the comp cars, I don't know that I'd want to copy the TA cages exactly. Even post 1970, the kit car program identified alterations that were improvements and a fair amount has been learned since then about about chassis rigidty and improvements. Looking at some of the pictures Barry put up, these cages appear to be pretty limited by the rule set of the day.
One of the biggest highlights in the ensuing years has been discovering the amount flex in the front third of the car and the need to have more rigidity in the firewall/A piller area and rocker area.
I'd agree.
I'd be looking to copy what Kevin Wesley has been doing to his car here: https://board.moparts.org/ubbthreads/show...e=0#Post8073886
IMHO, it's more practical for what I think you intend to do with the car.
[Re: RylisPro]
#1606565
04/14/14 03:49 PM
04/14/14 03:49 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Rylis... I've sat in the Posey and Gurney cars and took a bunch of pics... (even warmed up the engine of the 77 car before a vintage race at Road America!.. ~2012) I'll try to post later.
If I'm correct, I've read that the AAR/T/A were the first TransAm cars to have ever had their roll-cages designed using a computer.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#1606566
04/14/14 08:50 PM
04/14/14 08:50 PM
autoxcuda
So Cal
I remember Bob Tarozzi saying something like that.
It's an uncompromised race car. Nothing compromised for street use. Still 40+ years ago design. I think the biggest looking design differences today would involve the safety aspect.
[Re: autoxcuda]
#1606567
04/14/14 09:10 PM
04/14/14 09:10 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Just dropped my car off at the shop to get my cage welded using 1 3/4" .095 wall mild steel tubing. I'm not getting a 70's cage welded as the cage is going to have X bars at the doors since I'm keeping my door structure/windows. I may take the door beams out to save weight though. I was wondering how the cage is going to be tied to the front shock and wanted to get more ideas. I have a heater core in the way though. I saw that Dart Lite's cage and thought it was really cool, just wasn't sure if that shock bracing went through to the rest of the cage or if it just stops at the starfish looking portion of the firewall. I might not get that far as my brake master cylinder is in the way so well see...
[Re: RylisPro]
#1606569
04/14/14 09:25 PM
04/14/14 09:25 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Just a heads up, SCCA rules state 1.75" .120 wall IIRC.
Mopar to the bone!!!
[Re: 72Swinger]
#1606570
04/14/14 11:24 PM
04/14/14 11:24 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Took a screen shot off my phone. This is the SCCA GCR as of Feb. 2014 Over 2699 lbs. 1.75 x 0.095 Hopefully I don't have to use 0.120 wall as it would add more weight
[Re: RylisPro]
#1606572
04/15/14 01:05 AM
04/15/14 01:05 AM
Posts: 256 USA
Consulier
USA
There is a lateral bar that comes off the downtube to the backside of the underhood bar and a downtube from that intersection to the floor mount. Makes a nice triangle to tie in the forward section.
[Re: Consulier]
#1606573
04/15/14 01:10 AM
04/15/14 01:10 AM
72Swinger
Nebraska
My mentality is its better to err to the big side so your covered. Would suck to have to yank it all out later if your goals change IMO.
[Re: RylisPro]
#1606575
04/15/14 02:17 AM
04/15/14 02:17 AM
72Swinger
Nebraska
Im guessing a 20-40 lb difference between .095 and .120. You could weigh a stick of each and do the math. Around here un-cut DOM comes in 20ft sticks, be kind've a pain to weigh though. Edit: Found it .120 is .573 lb more per foot So 20ft of it is a whopping 11.46 lbs more.
[Re: RylisPro]
#1606577
04/23/14 11:59 AM
04/23/14 11:59 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
You guys make a great point, 0.120 it is I wonder how much more it will weigh?
1.75x0.095" wall DOM is 1.679lb/ft 1.75"x0.120" wall DOM is 2.089lb/ft
So if you used two 20' sticks, you'd be looking at a 16.5lb difference. Just a random number on length there..
http://www.onlinemetals.com/merchant.cfm...amp;top_cat=197
