Page 2 of 3 1 2 3
Re: how much is race fuel in your area? [Re: 1980volare] #1606498
04/13/14 01:49 PM
04/13/14 01:49 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
Just left Muncie Indiana and stopped by the gas station by the track, Renegade 110 leaded was $6.99
So I can get
renegade 110 for 6.99 plus the drive to get it 20 miles
cam 2 110 for 6.99 local
sunoco racing fuel 110 for $6.99 plus a 13 mile drive to get it
ll100 at the airport is $5.35
Re: how much is race fuel in your area? [Re: maxie] #1606499
04/13/14 06:30 PM
04/13/14 06:30 PM
Middleton, ID
curleysracecars Offline
Middleton, ID
Just payed $960 for a drum of Q16.
Kyle Curley
Re: how much is race fuel in your area? [Re: maxie] #1606500
04/13/14 07:08 PM
04/13/14 07:08 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Local station has cam2 110 octane for $6.85
can go to a town about 13 miles from here and get sunoco race fuel 110 octane $7.00
or back to the airport to get ll100 but heard all kinds of things about that.
What have you 'heard' about 100LL?
Re: how much is race fuel in your area? [Re: 135sohc] #1606501
04/13/14 07:20 PM
04/13/14 07:20 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
110 is $10 TO $11.50 around here.
Re: how much is race fuel in your area? [Re: Blucuda413] #1606502
04/13/14 07:36 PM
04/13/14 07:36 PM
Bad Axe,MI
E
EDDIEB Offline
EDDIEB  Offline
E
Bad Axe,MI
Just ordered a drum of vp 110 for $385
Re: how much is race fuel in your area? [Re: 135sohc] #1606503
04/13/14 07:58 PM
04/13/14 07:58 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
I have run it before with no problems. I just add a little marvel mystery oil. I just hear people back and forth about the pros and cons of it. High altitude, low rpm blah blah blah. There is a website that sells race gas and of course they tell you how bad av gas is
I had done a search for av gas on moparts and there was a post talking about dyno results of av gas and race gas, but I couldn't read the post
Re: how much is race fuel in your area? [Re: maxie] #1606504
04/13/14 08:00 PM
04/13/14 08:00 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
How do you guys transport a drum home and then unload it out of the truck. I hear people say they roll the drum out onto old tires
Re: how much is race fuel in your area? [Re: maxie] #1606505
04/13/14 09:21 PM
04/13/14 09:21 PM
Middleton, ID
Middleton, ID
Drum in the bed of the truck. Use a barrel clamp and overhead hoist to pick it up, and then drive out from under it.
Kyle Curley
Re: how much is race fuel in your area? [Re: curleysracecars] #1606506
04/13/14 10:07 PM
04/13/14 10:07 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
turn on side roll down ramp.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: how much is race fuel in your area? [Re: 1967dartgt] #1606507
04/13/14 10:22 PM
04/13/14 10:22 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
92 & 93 pump is about $3.95 a gallon right now in Md. I believe 110 race gas is about $10. a gallon. We have a Sunoco that I think still has 98 at the pump and its almost $10. a gallon also. I run the pump but this pump gas seems to get worse every year so I think about every third tank of pump I may add a few gallons of race gas. Ron
Re: how much is race fuel in your area? [Re: 1967dartgt] #1606508
04/13/14 10:23 PM
04/13/14 10:23 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Just paid $8.99 for VP110 at the BP near PRP.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: how much is race fuel in your area? [Re: maxie] #1606509
04/14/14 01:52 AM
04/14/14 01:52 AM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
Have used the 100LL for over 15 years with no problems . It does stain your carb but you should clean it now & then anyway . Change filter once a year everything is fine . Gary
Re: how much is race fuel in your area? [Re: Gabby63] #1606510
04/14/14 08:07 AM
04/14/14 08:07 AM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
$75.00 for a 5 gallon pal of VP NO2 120+ Octane
Re: how much is race fuel in your area? [Re: steeldust] #1606511
04/14/14 08:33 AM
04/14/14 08:33 AM
Cairns Queensland Australia. T...
V
vc360 Offline
vc360  Offline
V
LMAO try $250 Aussie per 20 litres which is about 4.5 gallons for VP ms109. Normal unleaded fuel here is 1.50 /litre.
Re: how much is race fuel in your area? [Re: vc360] #1606512
04/14/14 12:07 PM
04/14/14 12:07 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
$750.00 for a 45 gallon drum of VP C-12 up here.
That equates to about $14.00 / US gallon & US dollars . A "Little" pricey, but what do you do if you need it....
It seems to creep up about 10% every year, but what doesn't....?
Re: how much is race fuel in your area? [Re: D-50] #1606513
04/14/14 12:13 PM
04/14/14 12:13 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
I run 93 it is around $3.40 at the moment. I bought some 110 a couple of years ago at the track and it was $9.00. That is why I went with a pump gas motor.
Wow, cause we are paying $3.48 a gal for 87 pump swill up here in the north. 110 is $7 and C-16 is running around $13
Re: how much is race fuel in your area? [Re: mopar dave] #1606514
04/14/14 12:16 PM
04/14/14 12:16 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
don't know my local race fuel price, but I did find a new race fuel called RENEGADE. they claim to be every bit as good as VP, but with better pricing. 95 octane unleaded 5gal for $38 and the Rat man 108oct. oxygenated for $48/5gal. pal. that's about $25 less per pal compared to VP. anyone here ever use Renegade race fuel?
A local speed shop sells Renegade 16 from a 55 gal drum. Costs about $12 a gallon. Red instead of VP blue.
Re: how much is race fuel in your area? [Re: 1980volare] #1606515
04/14/14 12:16 PM
04/14/14 12:16 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
3.14, filled up today
Same here
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: how much is race fuel in your area? [Re: maxie] #1606516
04/14/14 12:17 PM
04/14/14 12:17 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I use straps and my engine hoist
Re: how much is race fuel in your area? [Re: Airwoofer] #1606517
04/14/14 08:46 PM
04/14/14 08:46 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I was wrong, I just bought some Sonoco 93 yesterday and it was $3.98 a gallon.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Page 2 of 3 1 2 3
