Re: Brake light switch issue
[Re: Prodart440]
#1606180
04/13/14 06:23 PM
04/13/14 06:23 PM
Posts: 1,028 NB, Canada
moparfan53
NB, Canada
Nudder view
So here is what I did to fix it. Thanks first to the pictures in the thread, they helped a lot.
The bracket was bent. So after fighting to get it out I fought to bend it back. After bending it back I noticed in the pictures that it is bolted to the car with the top two holes, and mine was bolted using the bottom two. I bolted it up like the pictures and it works perfectly!!
Glad you got it fixed! Thanks for letting us know what the problem was.
