Re: Caltract spring problem
[Re: josh426]
#1604846
04/08/14 06:26 PM
04/08/14 06:26 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
1964 Plymouth with rear wheels hanging free, looks like left rear is hanging lower than the right rear. Has anybody else had this experience?
They always will,the right is a higher spring rate for rotational loading.
[Re: Thumperdart]
#1604848
04/08/14 08:06 PM
04/08/14 08:06 PM
Posts: 861 lancaster,california
johnnycuda
There are no left or right spring, can be installed on either side.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: Thumperdart]
#1604853
04/08/14 09:40 PM
04/08/14 09:40 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Guys if this is a new install then the car has the preload in it because it was set up with a conventional spring. So the car was leveled with the torsion bars. So first time you let it down a lot of times it looks like a train reck. I would set it up on scales because you can make torsion bar adjustments and do your preload adjustments you can make the car level and have preload set.
JAKES AUTOMOTIVE
[Re: JAKE68]
#1604854
04/08/14 09:46 PM
04/08/14 09:46 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Jake your correct , but in this case they are just Free hanging. Further, Josh426 states that it Looks like the left side is hanging lower, doesnt say how much. Might not be a issue at all. How much lower Josh? 1/4",1/2" probably fine. 1",3" probably a problem.
[Re: mopar dave]
#1604860
04/09/14 02:41 PM
04/09/14 02:41 PM
Posts: 49 mn.
taxidermy man
mn.
had the same problem when I installed mine. you cant just crank the u bolts down with a finish torque on them. they need to be torqued slowly and evenly. I torqued mine in a crosshatch pattern 20ftlb at a time and each side til I got to the finish torque which I think was 80#. at that point when I set the car down it was level.
I thought I did that on mine, maybe I'll re-check that.
[Re: josh426]
#1604862
04/09/14 07:39 PM
04/09/14 07:39 PM
Posts: 11,688 W. Kentucky
justinp61
W. Kentucky
What does it look like sitting on the ground?
