Re: 915 and 516 CC's
[Re: Sport440]
#1604300
04/09/14 12:11 AM
04/09/14 12:11 AM
Posts: 4,314 Prospect, PA
BSB67
Prospect, PA
How much do you think the seat and valve combined are ground on a wore out set of heads?
[Re: Sport440]
#1604303
04/09/14 08:34 AM
04/09/14 08:34 AM
BSB67
Prospect, PA
One of us is doing the math wrong. I too would guess 0.010" to 0.020" 0.020" drop of both valves is almost 2 cc. If my math is wrong, please let me know. Surface area of the entire valve verses the notch is not a good comparison. My point is that if someone is getting 84 cc on a set of 915s, it might be be that it has had one or two NAPA valve grinds. Maybe just factory variability...I don't know
[Re: elmor353]
#1604304
04/09/14 11:53 AM
04/09/14 11:53 AM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
Can anyone tell me how many cc's the combustion chambers are on these heads?
The sets I've measured were between 80-82 cc
[Re: BSB67]
#1604305
04/09/14 01:50 PM
04/09/14 01:50 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
No your Math is correct, decided to check it myself instead of guesstimate.
At 0.010 on both a 2.14 and 1.81 valve = 1.011 cc
At 0.020 on both double that = 2.022 cc
My eyeball measurement wasnt very correct
Thanks for the correction
