Best alternator for street strip drag week survival
#1602804
04/03/14 06:46 PM
04/03/14 06:46 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
Hi, I need to pick an alternator for my 31 Plymouth coupe Drag Week project. It needs to be extra - reliable Easy to find a bolt in replacement on the road trip As light as possible Enuff amps to run an MSD6 AL, electric fuel pump, all the lights in the car, and charge the little lightweight battery up fast if it gets run down Any suggestions? Thanks Joel ![](/ubbthreads/images/graemlins/smile.gif)
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Best alternator for street strip drag week survival
[Re: Hemi_Joel]
#1602806
04/03/14 07:11 PM
04/03/14 07:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm running a Denso 85A and it runs the Rampage fine with some to spare... its your everyday production alt found on many Chrysler cars... that way if you dump one for any reason you can get one easy... mine has been on the race car for 14 years now and I have the same one on the Rampage... I had to change pulleies since it comes with a multy cog belt... I use a V belt... also I run more electrial stuff than you ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Hemi_Joel]
#1602808
04/03/14 09:54 PM
04/03/14 09:54 PM
Posts: 12,419 Taxes & Virus's R-US, NY
Dragula
The Mancini Denso ones run a little hot, but they pump up the voltage real nice, and I never had an issue with mine in the +3000 miles I put on my Hot rod with 4.56 gears! Nice, small, light, and +14vdc... By the way, if its the car in your sig, that's got 4 headlights and draws 20 amps right there... ![](http://i427.photobucket.com/albums/pp357/cudahalr/78Dodge_D100/DSC00002.jpg)
[Re: Hemi_Joel]
#1602809
04/03/14 09:57 PM
04/03/14 09:57 PM
MR_P_BODY
If I went to the parts store, what make year and model would I tell them it was for?
I dont know... you could ask the parts guy for it.. you could try one for a Stratus ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Thumperdart]
#1602814
04/04/14 01:01 AM
04/04/14 01:01 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
I use a GM CS130/140 amp alternator. Best thing is if my spare has problems any auto parts store will have one.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#1602815
04/04/14 02:45 AM
04/04/14 02:45 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
I've ran one of Andy's kits with the 60 amp Denso on the Valiant. Completed two drag weeks with it, no problems, 4 electric fans, electric fuel pump, MSD ignition.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: AndyF]
#1602818
04/04/14 10:57 AM
04/04/14 10:57 AM
Posts: 456 corpus christi tex
Cheatham
corpus christi tex
What engine? Mancini has the Denso kits for SB, BB and Hemi engines.
same here but i think 440source has the same kit which i have.
[Re: bwhackd34]
#1602823
04/04/14 12:06 PM
04/04/14 12:06 PM
MR_P_BODY
also make sure you do the "MAD" modification or something similar...
What is this "MAD" mod your talking about ![](/ubbthreads/images/graemlins/wave.gif)
