Re: RPM at the stripe?? [Re: hemi-itis] #1602187
04/03/14 02:18 PM
04/03/14 02:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
To be honest I wouldnt change anything till you get
the racepac installed and see if your tack is just off
which very well could be your issue
Re: RPM at the stripe?? [Re: MR_P_BODY] #1602188
04/03/14 06:15 PM
04/03/14 06:15 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
All these RPM/gear/stripe numbers are useless without the MPH. If I have the car slowed to run 9.50@143 it only turns 6700 instead of 6900 at 147.
Doug
Re: RPM at the stripe?? [Re: dvw] #1602189
04/03/14 07:06 PM
04/03/14 07:06 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Wow some of you guys really twist them. I shift about 6200 and trap about 6400 at 10.70's and almost 125. But my mild 493 seems to like that rpm range. Ron
Re: RPM at the stripe?? [Re: dvw] #1602190
04/03/14 11:31 PM
04/03/14 11:31 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
All these RPM/gear/stripe numbers are useless without the MPH. If I have the car slowed to run [Email]9.50@143[/Email] it only turns 6700 instead of 6900 at 147.
Doug
like i said et means nothing mph determines trap rpms. watched some old films of 1964 super stockers, they ran 11.60s at 130 mph. a lot of difference then and now. today some cars run FAST out the back door.
Re: RPM at the stripe?? [Re: MR_P_BODY] #1602191
04/03/14 11:48 PM
04/03/14 11:48 PM
Great Neck,LI,new york
hemi-itis Offline OP
That would be a hoot!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: RPM at the stripe?? [Re: hemi-itis] #1602192
04/08/14 02:34 AM
04/08/14 02:34 AM
Pulled the trans tonight.Found the new max lug gearset scored the stater causing a pressure bleed off,Gotta do some measuring to figure out why it got scored
