Re: My new motor 540 B1, Indy Maxx
[Re: Brian Hafliger]
#1601532
04/01/14 03:32 PM
04/01/14 03:32 PM
Posts: 474 Alberta, Canada
451Guy
Alberta, Canada
Looks awesome!!!!
Who's Valve covers are those?
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T Best ET 11.39 @ 118.11
[Re: 451Guy]
#1601533
04/02/14 02:17 AM
04/02/14 02:17 AM
Posts: 916 SE Washington
Forest
SE Washington
Looks awesome!!!!
Jeff Johnston's Billet Fab
[Re: Forest]
#1601534
04/02/14 08:29 AM
04/02/14 08:29 AM
Posts: 159 australia
charger410
australia
That's a great engine for your car. Like your colour coordination and detailing. That' engines certainly going to make things entertaining
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
Re: My new motor 540 B1, Indy Maxx UPDATED pics motors in
[Re: ProSport]
#1601538
04/07/14 01:08 AM
04/07/14 01:08 AM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
Looking good..I hope that pickup point for the vacuum pump works for ya..
[Re: Forest]
#1601540
04/07/14 10:21 AM
04/07/14 10:21 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Beautiful car! If the motor makes 980 hp, and the race weight is 2500 even, the calculator says 8.00. Based on some other builds similar, it ought to go 8.25 or better!
[Re: gregsdart]
#1601542
04/07/14 10:58 AM
04/07/14 10:58 AM
Forest
SE Washington
Mine works there, but I have a special baffle built into the top of the valve cover to help separate oil out. As I recall, it turned out to be the best spot for my motor.
I hope it works here too, yes there is a baffle under the cover.
I am anxious to see how well it runs too!
[Re: 451Guy]
#1601543
04/07/14 12:58 PM
04/07/14 12:58 PM
Al_Alguire
Las Vegas
I hope it does work for you Forest. I only ask because there is a LOT of oil that gets caught up top in a B1 deal, not like with an Indy or stock type head. We had mine there once as well and it would suck a fair amount of oil. We assume it was under decal at the top end. But the baffling and fitting inside the cover will play a roll as well. The best thing we did was got to a Star vacuum fitting in the cover.
[Re: HardcoreB]
#1601546
04/08/14 09:48 PM
04/08/14 09:48 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
Looks awesome man! Good Luck!
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: Mopar-Al]
#1601548
04/10/14 01:39 AM
04/10/14 01:39 AM
Forest
SE Washington
Forest, what lifterts are you running? And do they have an offset? Are you useing 7/16 pushrods on the exhaust? ALAN
Isky lifters with a .180" offset and yes 7/16" pushrods.
