Re: Car stalls on hard braking
[Re: Kern Dog]
#1600941
04/01/14 10:42 AM
04/01/14 10:42 AM
Posts: 3,298 West Coast, USA
jbc426
West Coast, USA
Put the Holley anti-slosh vents in your float bowls.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#1600942
04/01/14 11:27 AM
04/01/14 11:27 AM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
Hi Greg. As stated above, 11 LBS is to high. 7 max should be plenty for your car. Regulator goes between the fuel pump, and the carb. Putting vent tubes on is a good idea, but not really necessary (but go ahead and try them out). Sounds to me like your starving the primary bowl when stopping hard. When you accelerate hard, does the car starve out at high RPMS too? On a carb with glass sights, go to just under, the half way up mark in the glass. If your carb. has the solid screw offs to sight the fuel level, then yes adjust to have the fuel trickle out over the threads is good. I have never needed the vent tubes on my car, and you know how I drive! My carb. is set up as I said above. Never a problem. Good luck, M
[Re: bigblock340power]
#1600943
04/01/14 11:30 AM
04/01/14 11:30 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If he's running center hung bowls with 11psi it is very possible that on a hard stop the float is being over powered and flooding the engine.
If you want to run a return style regulator, probably a good idea, you can but the regulator still needs to be between the pump and carb.
[Re: Supercuda]
#1600944
04/01/14 12:18 PM
04/01/14 12:18 PM
Posts: 3,344 Central TX
roe
Central TX
I use the basic style of regulator that's just one line in and out. It was less than $10 at the parts house, they all carry them. My setup goes stock mech fuel pump>filter> pressure regulator> carb
roe
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
#1600946
04/03/14 02:42 AM
04/03/14 02:42 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I switched back to the Holley pump. It reads no more than 7 lbs, just as suggested.
I may spend the time to install a regulator with the Carter pump sometime later. Thanks everyone!
[Re: jbc426]
#1600947
04/07/14 03:32 AM
04/07/14 03:32 AM
Kern Dog
Granite Bay CA
The Demon has those but I need to replace mine. I dropped the metering block and cracked it a few months back. I didn't expect that it could cause this. Its worth a try anyways, thanks!
