Re: 8 3/4 Rear Drum Brake help...
[Re: DoctorDiff]
#1600244
03/30/14 11:07 PM
03/30/14 11:07 PM
RapidRobert
Not a dealbreaker but the short spring (coming up from the short shoe) goes on the anchor before the longer spring
[Re: MuuMuu101]
#1600249
03/30/14 11:49 PM
03/30/14 11:49 PM
RapidRobert
Yes I forgot to add that your short springs are on the bottom. I'd wipe the linings/drums with some brake kleen then install the drums & spoon em up till with the wheel on you spin the tire/wheel by hand (fronts) & adj till you hear (but do not feel it slowing the wheel down) a slight "tick" at one point in the wheels' revolution. On the rears up on 2 heavy duty stands under the housing idle it in gear with a helper in the dr seat adj till you hear the same slight tick. Have him stop the wheels with the brake then you spoon farther then you holler & he lets off the pedal & you listen for the tick. Being safety conscious of course. Adj em again in several weeks
