Re: Converters, Coan or ATI?
[Re: Sport440]
#1599824
03/28/14 07:37 PM
03/28/14 07:37 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
Love the ATI behind my small blk
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: Chris2581]
#1599829
03/28/14 11:15 PM
03/28/14 11:15 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: Chris2581]
#1599832
03/29/14 01:24 AM
03/29/14 01:24 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Turbo Action.... ![](/ubbthreads/images/graemlins/thumbs.gif)
www.turboaction.com
This is what I run... been a couple of real good convs and TA conv have been what MP sells for YEARS... he has been a mopar guy for years ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 68roadrunner]
#1599836
03/29/14 12:49 PM
03/29/14 12:49 PM
Posts: 11,732 Portage,michigan
B3422W5
Portage,michigan
Sounds like whatever you had worked well. Why not have whoever built it make you another ![](/ubbthreads/images/graemlins/confused.gif)
[Re: wyoming]
#1599837
03/29/14 01:01 PM
03/29/14 01:01 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
All of those can be good choices, myself I have a Dynamic, all the guys mentioned build good convertors, one of the main keys is communication in both directions.
I agree with that. I use Dynamic and Turbo Action and they have been great as are any of the mentioned converters in this post. We should make a converter list or something like that and put it in the tech area as this question gets asked about twice a week so maybe it would be a good idea to make a list up of the good converter companies. Ron
[Re: B3422W5]
#1599839
03/29/14 01:27 PM
03/29/14 01:27 PM
Posts: 11,689 W. Kentucky
justinp61
W. Kentucky
The converter is five years old and has maybe 50 1/8 mile passes and I'd guess less than 3000 street miles on it. The 60' and mph started going away two years go, I've lost .3-.4 in the 1/8.
At first I thought it was a transmission problem. At cruise in high gear if it was matted the rpms would jump to 6000 then pull from there. So I built a new 727 over the winter, everything new. Put it in and the same thing as the old one on the street. Pulled the new trans and let a local shop take it apart and find where I had screwed up. I picked it up yesterday, they didn't find anything wrong.
So I don't want to spend the money to have this one freshened up and have the same problem start in three years. I'll spend the money on a good one this time.
